29376 Discussions
Spurious F95 standard compliance warnings?
bilklebatnasagov
To turn the screws on our compiler warnings gauntlet, I asked all the compilers in our gauntlet to report F95 conformance items. This caused our two Intel compilers to start warning about items that are tangential to standard conformance?
Intel-10.1.015
fortcom: Warning: somecode.f90, line 1408: The field width is too small for the number of fractional digits. [5]
' of the cap is: ', f7.5 )
Intel-11.0.025
somecode.f90(1408): warning #6894: The field width is too small for the number of fractional digits. [5]
Confused,
-- Bil
You are correct that this is not a standards issue. The compiler is, I suppose, trying to be helpful in warning you that a W of 7 is not enough to fully represent a value with a D of 5, since there needs to be three spaces for the sign, leading digit and radix point.
In my opinion, this warning should not be issued under the standards switch and I'll let the developers know about it. It might be useful to note under a "usage" class of diagnostics.
bilklebatnasagov
I agree, the warning is certainly valid, but does not belong in the standards category.
FWIW, I think the format was set at 7.5 because the value that fills it is positive-definite.
mvdsluys
Is there a way to switch off just this warning (in v.11.1)?
Thanks!
-diag-disable 6894
should do it.
mvdsluys
Perfect, cheers! :-)
