Stack overflow on array copy
Benedikt_R_
Hi
I'm using "Intel(R) Visual Fortran Compiler XE for applications running on IA-32, Version 15.0.0.108 Build 20140726"
My program craches with an stack-overflow. On standard-error there's a stack-trace pointing to a codeline, where a part of an array is copied:
          arr(i0: j0)= arr(i1: j1)
I read somewhere, that the compilter has to create a copy of the copied portion because the compiler cannot dtermine, wether source- and the target-memory do overlap (https://software.intel.com/en-us/node/524873).
Actually I do know, that they do not overlap. Is there a way to give this "promise" to the compiler to force the comiler to creatinon-copy-code?
Benedikt
JVanB
Valued Contributor II
DO CONCURRENT (I = i0:j0)
   arr(I) = arr(i1-i0+I)
END DO
I am not aware of ways to tell the compiler to avoid the copy in this case. I suggest compiling with /heap-arrays (Fortran > Optimization > Heap Arrays > 0)
JVanB
END DO
The DO CONCURRENT helps the compiler decide that the loop is safe to vectorize.
FortranFan
The following should also work:
      Assoc_Arr: ASSOCIATE ( tmp1 => array(i0:j0), tmp2 => array(i1:j1) )
         tmp1 = tmp2
      END ASSOCIATE Assoc_Arr
JVanB
Hmmm... I didn't think that ASSOCIATE had rules about aliasing like procedures do. Let's try an experiment:
program P
   implicit none
   integer arr(10)
   integer i
   integer, parameter :: arr0(size(arr)) = [(i,i=1,size(arr))]
   integer i0,j0,i1,j1
   write(*,'(a)') 'Array assignment'
   arr = arr0
   call set1(i0,j0,i1,j1)
   arr(i0:j0) = arr(i1:j1)
   write(*,5) arr
   arr = arr0
   call set2(i0,j0,i1,j1)
   write(*,5) arr
   write(*,'(a)') 'Associate'
   arr = arr0
   associate(T0 => arr(i0:j0), T1 => arr(i1:j1))
      T0 = T1
   end associate
   write(*,5) arr
   arr = arr0
      T0 = T1
   end associate
   write(*,5) arr
   write(*,'(a)') 'Subroutine'
   arr = arr0
   call copy(arr(i0:j0),arr(i1:j1),j0-i0+1)
   write(*,5) arr
   arr = arr0
   write(*,5) arr
   write(*,'(a)') 'Forall'
   arr = arr0
   forall(i=i0:j0) arr(i) = arr(i1-i0+i)
   write(*,5) arr
   arr = arr0
   write(*,5) arr
   write(*,'(a)') 'Do concurrent'
   arr = arr0
   do concurrent(i=i0:j0)
   end do
   write(*,5) arr
   arr = arr0
   end do
   write(*,5) arr
5 format(*(i0:1x))
   contains
      subroutine copy(arr0,arr1,n)
         integer n
         integer arr0(n),arr1(n)
         arr0 = arr1
      end subroutine copy
end program P
subroutine set1(i0,j0,i1,j1)
   i0 = 3
   j0 = 5
   i1 = 4
   j1 = 6
end subroutine set1
subroutine set2(i0,j0,i1,j1)
   i0 = 5
   j0 = 7
   i1 = 4
   j1 = 6
end subroutine set2
Output with ifort:
Array assignment
1 2 4 5 6 6 7 8 9 10
1 2 3 4 4 5 6 8 9 10
Associate
1 2 3 4 4 4 4 8 9 10
Subroutine
Forall
Do concurrent
So ASSOCIATE has the same result as the subroutine and DO CONCURRENT which do have aliasing rules. I get similar results for gfortran. Where does it talk about aliasing rules for the ASSOCIATE construct in the standard?
FortranFan
I assume you've referred to J3/04-007 Latest Working Draft of the Fortran 2003 standard, May 10 2014: sections 8.1.4 and 16.4.1.5.  Now I've a tough time reading these standards documents. so it's The Fortran 2003 Handbook by Adams et al. to the rescue: section 8.2.2 of this book says about the association during the execution of the ASSOCIATE construct, "This process is somewhat similar to what happens in a procedure call with the associate name taking the role of the dummy argument."  In the context in this thread, I personally would prefer ASSOCIATE over DO CONCURRENT.
andrew_4619
Should you compile with Qparallel  or is that implicit in Qmkl? If you're not enabling auto-parallel, there is no benefit to DO CONCURRENT I believe.
FortranFan
Here's another test using floating point variables you can consider:
   PROGRAM p
      USE, INTRINSIC :: ISO_FORTRAN_ENV, ONLY : I4 => INT32, DP => REAL64
      IMPLICIT NONE
      INTEGER(I4), PARAMETER :: MAXARR = 2**28
      INTEGER(I4), PARAMETER :: MAXREPEAT = 5
      INTEGER(I4) :: i0
      INTEGER(I4) :: j0
      INTEGER(I4) :: i1
      INTEGER(I4) :: j1
      INTEGER(I4) :: Istat
      INTEGER(I4) :: I
      INTEGER(I4) :: Counter
      INTEGER(I4) :: Overlap
      REAL(DP), PARAMETER :: EPSILON_DP = EPSILON(1.0_dp)
      REAL(DP), ALLOCATABLE :: array(:)
      REAL(DP) :: Start_Time = 0_dp
      REAL(DP) :: End_Time = 0_dp
      REAL(DP) :: CpuTimes_Assign(MAXREPEAT)
      REAL(DP) :: CpuTimes_DoConcurrent(MAXREPEAT)
      REAL(DP) :: CpuTimes_Associate(MAXREPEAT)
      CHARACTER(LEN=*), PARAMETER :: FMT_CPU = "(A, T40, F8.3, A)"
      CHARACTER(LEN=2048) :: ErrorAlloc
      ALLOCATE(array(MAXARR), SOURCE=0.0_dp, STAT=Istat, ERRMSG=ErrorAlloc)
      IF (Istat /= 0) THEN
         PRINT *, " Allocation of array failed: ", ErrorAlloc(1:LEN_TRIM(ErrorAlloc))
         STOP
      END IF
      Overlap = 0
      PRINT *, " ** With Overlap of ", Overlap
      i0 = 1
      j0 = MAXARR/2
      i1 = j0 + 1 - Overlap
      j1 = i1 + MAXARR/2 - 1
      CpuTimes_Assign = 0.0_dp
      CpuTimes_DoConcurrent = 0.0_dp
      CpuTimes_Associate = 0.0_dp
      PRINT *, "Array assignment:"
      Loop_Repeat_Assign: DO Counter = 1, MAXREPEAT
         PRINT *, "   Trial ", Counter
         !.. Initialize the array using random numbers
         CALL RANDOM_NUMBER(array)
         CALL CPU_TIME(Start_Time)
         array(i0:j0) = array(i1:j1)
         CALL CPU_TIME(End_Time)
         CpuTimes_Assign(Counter) = (End_Time - Start_Time)
         IF (ABS(array(j0)-array(j1)) > EPSILON_DP) THEN
            PRINT *, " Copy failed."
            CYCLE Loop_Repeat_Assign
         END IF
         IF (Counter == 1) THEN
            PRINT *, " array(i0) = ", array(i0)
            PRINT *, " array(j0) = ", array(j0)
            PRINT *, " array(i1) = ", array(i1)
            PRINT *, " array(j1) = ", array(j1)
         END IF
         WRITE(*, FMT=FMT_CPU) "   CPU Time: ", CpuTimes_Assign(Counter), " seconds."
      END DO Loop_Repeat_Assign
      PRINT *, "DO CONCURRENT:"
      Loop_Repeat_DO: DO Counter = 1, MAXREPEAT
         DO CONCURRENT ( I = i0:j0 )
            array(I) = array(i1 - i0 + I)
         END DO
         CpuTimes_DoConcurrent(Counter) = (End_Time - Start_Time)
            CYCLE Loop_Repeat_DO
         END IF
         END IF
         WRITE(*, FMT=FMT_CPU) "   CPU Time: ", CpuTimes_DoConcurrent(Counter), " seconds."
      END DO Loop_Repeat_DO
      PRINT *, "ASSOCIATE:"
      Loop_Repeat_Assoc: DO Counter = 1, MAXREPEAT
            tmp1 = tmp2
         CpuTimes_Associate(Counter) = (End_Time - Start_Time)
            CYCLE Loop_Repeat_Assoc
         END IF
         END IF
         WRITE(*, FMT=FMT_CPU) "   CPU Time: ", CpuTimes_Associate(Counter), " seconds."
      END DO Loop_Repeat_Assoc
      WRITE(*, FMT=FMT_CPU) "Array Assignment: Average CPU Time ",                                  &
                            SUM(CpuTimes_Assign)/REAL(MAXREPEAT, KIND=DP),  " seconds."
      WRITE(*, FMT=FMT_CPU) "DO CONCURRENT:    Average CPU Time ",                                  &
                           SUM(CpuTimes_DoConcurrent)/REAL(MAXREPEAT, KIND=DP),                     &
                           " seconds."
      WRITE(*, FMT=FMT_CPU) "ASSOCIATE:        Average CPU Time ",                                  &
                           SUM(CpuTimes_Associate)/REAL(MAXREPEAT, KIND=DP),                        &
                           " seconds."
      DEALLOCATE(array, STAT=Istat, ERRMSG=ErrorAlloc)
         PRINT *, " Deallocation of array failed. ", ErrorAlloc(1:LEN_TRIM(ErrorAlloc))
         STOP
      END IF
      STOP
   END PROGRAM p
The results I observe:
  ** With Overlap of  0
 Array assignment:
    Trial  1
  array(i0) =  2.649255667434409E-003
  array(j0) =  0.829067121479056
  array(i1) =  2.649255667434409E-003
  array(j1) =  0.829067121479056
   CPU Time:                              0.499 seconds.
    Trial  2
    Trial  3
    Trial  4
    Trial  5
   CPU Time:                              0.484 seconds.
 DO CONCURRENT:
    Trial  1
  array(i0) =  0.657694300591952
  array(j0) =  0.556066471741371
  array(i1) =  0.657694300591952
  array(j1) =  0.556066471741371
   CPU Time:                              0.640 seconds.
    Trial  2
   CPU Time:                              0.624 seconds.
    Trial  3
    Trial  4
   CPU Time:                              0.655 seconds.
    Trial  5
   CPU Time:                              0.593 seconds.
 ASSOCIATE:
    Trial  1
  array(i0) =  0.865167717234815
  array(j0) =  0.555618009170298
  array(i1) =  0.865167717234815
  array(j1) =  0.555618009170298
   CPU Time:                              0.203 seconds.
    Trial  2
    Trial  3
   CPU Time:                              0.218 seconds.
    Trial  4
    Trial  5
Array Assignment: Average CPU Time        0.496 seconds.
DO CONCURRENT:    Average CPU Time        0.630 seconds.
ASSOCIATE:        Average CPU Time        0.206 seconds.
Compiled with:
ifort /c /nologo /O3 /Qparallel /heap-arrays0 /standard-semantics /stand:f08
/traceback /libs:static /threads
My observations generally have been that in order for DO CONCURRENT to be effective, the computational intensity or the array sizes need to be above a certain threshold; otherwise, the overhead of "setting up" the parallel operations can overwhelm the benefits.
jimdempseyatthecove
To post #13 program I added
      SUBROUTINE COPY8(b0,e0,b1,e1)
      INTEGER b0,e0,b1,e1
      INTEGER i,b
      b = b1-b0
!DIR$ IVDEP
!DIR$ VECTOR NONTEMPORAL
      DO I = b0,e0
        Arr(i) = Arr(i+b)
      END DO
      END SUBROUTINE
        DO K=1,rep
          CALL Copy8(1,e0,b1,i)
          CALL Copy8(b1,i,1,e0)
        END DO
        Call STOPWATCH('LOOP WITH !DIR$ IVDEP and !DIR$ VECTOR NONTEMPORAL')
Results:
      0.00 INIT
      0.00 Array Operator
      0.12 DO CONCURRENT
      0.62 Classical Loop
      0.41 Array Operator: Different Arrays
      0.16 BLAS
      0.12 LOOP WITH !DIR$ IVDEP
      0.13 associate
      0.08 LOOP WITH !DIR$ IVDEP and !DIR$ VECTOR NONTEMPORAL
      0.00 INIT
      0.00 Array Operator
      0.24 DO CONCURRENT
      1.21 Classical Loop
      0.78 Array Operator: Different Arrays
      0.23 BLAS
      0.24 LOOP WITH !DIR$ IVDEP
      0.24 associate
      0.16 LOOP WITH !DIR$ IVDEP and !DIR$ VECTOR NONTEMPORAL
      0.01 INIT
      0.00 Array Operator
      0.49 DO CONCURRENT
      2.43 Classical Loop
      1.55 Array Operator: Different Arrays
      0.46 BLAS
      0.47 LOOP WITH !DIR$ IVDEP
      0.49 associate
      0.31 LOOP WITH !DIR$ IVDEP and !DIR$ VECTOR NONTEMPORAL
      0.01 INIT
      0.00 Array Operator
      0.96 DO CONCURRENT
      4.85 Classical Loop
      3.07 Array Operator: Different Arrays
      0.93 BLAS
      0.92 LOOP WITH !DIR$ IVDEP
      0.97 associate
      0.63 LOOP WITH !DIR$ IVDEP and !DIR$ VECTOR NONTEMPORAL
Clearly a winner
Jim Dempsey
jimdempseyatthecove
The above timings was without /Qparallel and with the sequential MKL
The following is with /Qparallel and the parallel MKL
      0.00 INIT
      0.00 Array Operator
      0.12 DO CONCURRENT
      0.64 Classical Loop
      0.40 Array Operator: Different Arrays
      0.16 BLAS
      0.12 associate
      0.00 INIT
      0.00 Array Operator
      0.24 DO CONCURRENT
      1.31 Classical Loop
      0.77 Array Operator: Different Arrays
      0.24 BLAS
      0.22 LOOP WITH !DIR$ IVDEP
      0.24 associate
      0.01 INIT
      0.00 Array Operator
      0.48 DO CONCURRENT
      2.45 Classical Loop
      1.54 Array Operator: Different Arrays
      0.46 BLAS
      0.48 associate
      0.01 INIT
      0.00 Array Operator
      0.97 DO CONCURRENT
      4.93 Classical Loop
      0.91 BLAS
      0.97 associate
BLAS marginally improved, DO CONCURRENT is inconclusive, IVDEP with NONTEMPORAL is the winner at 1.44x faster than BLAS.
Note, the above result is not to be taken as a generalization, rather it is for the specific conditions of the test program.
Jim Dempsey
