Stackoverflow ifort
NC1
I am having some issues with setting the size of the stack when compiling a fortran code via command line.
When I use Visual Studio with ifort, I know that I can go to: Properties → Linker → System and then change the Stack Commit/Reserve size.
Now if I open Intel oneAPI command prompt for Intel 64 for Visual Studio 2019, I am usually able to compile my codes by doing:
ifort -O2 -c -Qopenmp module_master.f90
ifort -O2 -c -Qopenmp main_program.f90
ifort -o main.out -O2 -Qopenmp main_program.f90 module_master.f90
When I run the file I get a stackoverflow error. I tried doing:
ifort -o main.out -O2 -Qopenmp main_program.f90 module_master.f90 -stack:999999999
But the compiler just ignored the stack flag. Anyone knows how can I compile this via command line?
mecej4
Before the -stack:xxxx option add -link .
Are you aware that you are compiling the Fortran source files twice with the commands that you showed? This is almost harmless, but wasteful. After separately compiling the Fortran source files, you could have used
ifort -o main.out -O2 -Qopenmp main_program.obj module_master.obj -link -stack:999999900
mecej4
