29651 Discussions
Stange things using derived type allocatable
Andrew_Smith
Valued Contributor I
The following code gives output:
1.000000
2.000000
3.000000
4.000000
-4.3160208E+08
-4.3160208E+08
-4.3160208E+08
-4.3160208E+08
-4.3160208E+08
-4.3160208E+08
-4.3160208E+08
-4.3160208E+08
-4.3160208E+08
-4.3160208E+08
-4.3160208E+08
-4.3160208E+08
-4.3160208E+08
-4.3160208E+08
-4.3160208E+08
-4.3160208E+08
module
subs
implicit none
type defType
real, allocatable :: a(:), b(:,:)
end type
contains
subroutine
sub1(myElem, i, n)
type(defType), intent(inout) :: myElem
integer, intent(in) :: i, n
integer status
allocate(myElem%a(n), myElem%b(n,n), stat = status)
if (status == 0) then
myElem%a =
float(i)
else
continue
end if
end subroutine
end module
program
BugTest
use subs
implicit none
integer , parameter :: sz1 = 20, sz2 = 10000
type(defType) :: myArray(sz1)
integer i
do i = 1, sz1
call sub1(myArray(i),i,sz2)
end do
open(10, file = 'Vals.txt')
do i = 1, sz1
write(10, *) myArray(i)%a(1)
end do
close(10)
end
program
Using VS2005 SP1, IVF 10.1.024, Vista64 SP1
Run in debug mode with deafult project settings.
if I reduce sz2 to 1000 I get sequential number output as I expect.
If I use OpenMP for the first loop using 4 cores I get:
1.000000
-4.3160208E+08
-4.3160208E+08
-4.3160208E+08
-4.3160208E+08
6.000000
-4.3160208E+08
-4.3160208E+08
-4.3160208E+08
-4.3160208E+08
11.00000
-4.3160208E+08
-4.3160208E+08
-4.3160208E+08
-4.3160208E+08
16.00000
-4.3160208E+08
-4.3160208E+08
-4.3160208E+08
-4.3160208E+08
Regards Andrew
You're running out of virtual memory after the first four calls to sub by which time you have allocated 1,246,822,400 bytes of data. While the subsequent calls fail, the compiler is incorrectly setting the descriptor for the allocatable components assuming the allocate will succeed, and you get garbage. That bug is already being fixed.
Oh, you are undoubtedly building a 32-bit application. You need to add an x64 configuration in order to build for 64-bits. This is described in the on-disk documentation on adding a target configuration.
