Strange Forum message - security
DavidWhite
Valued Contributor II
Any ideas on this problem ... You have asked Firefox to connect securely to software.intel.com, but we can't confirm that your connection is secure. Normally, when you try to connect securely, sites will present trusted identification to prove that you are going to the right place. However, this site's identity can't be verified. What Should I Do? If you usually connect to this site without problems, this error could mean that someone is trying to impersonate the site, and you shouldn't continue. software.intel.com uses an invalid security certificate. The certificate is not trusted because the issuer certificate is not trusted. (Error code: sec_error_untrusted_issuer)
When you see this, get the certificate details and paste them into a reply here.  It should look something like this:
