29627 Discussions
Strange behavior in data assignment/output
Christoph_N_
I'm sorry for this unspecific subject but it's hard to find a title for this problem. I have the following minimal example:
File: base.f90
module m_type
  implicit none
  type mytype
    real(kind=8) :: array(6)
  end type mytype
  type (mytype) :: te
  data te%array /1.d0, 1.d0, 1.d0, 0.d0, 0.d0, 0.d0/
contains
  subroutine output_0(number, name)
    implicit none
    real(kind=8) :: number
    character(*) :: name
    write(*,*) name, number
  end subroutine output_0
  subroutine output_1(typ, name)
    implicit none
    type(mytype) :: typ
    write(*,*) name, typ%array
  end subroutine output_1
end module m_type
File: main.f90
program test
  use m_type
  implicit none
      integer, parameter :: steps = 10, periods = 10
      integer :: i1
      type(mytype) :: t(steps*periods)
      do i1 = 1, steps*periods
        t(i1) = te
      enddo
      call output_0(t(2)%array(1), "t2(1) = ")
      call output_1(te, "te = ")
!      call output_1(t(2), "t(2) = ")
!      write(*,*) t(steps)%array(1)
end program test
I would expect the following output:
 t2(1) =    1.00000000000000
 te =    1.00000000000000        1.00000000000000        1.00000000000000
  0.000000000000000E+000  0.000000000000000E+000  0.000000000000000E+000
Instead, I get the following:
ifort --version
ifort (IFORT) 13.0.0 20120731
Copyright (C) 1985-2012 Intel Corporation.  All rights reserved.
ifort base.f90 main.f90 -o Test
./Test
 t2(1) =   0.000000000000000E+000
This does not occur in the following cases:
  • -debug full
  • uncomment one of the two last lines in main.f90
  • use a single file for the code
  • only use "steps" as an upper boundary in the do-loop
Is there something wrong with the data-statement in module m_type (by the way, is there a way to define a type as a parameter?)? Or is this a compiler bug? gfortran works as expected, even if I use optimization.
Thank you!
I can reproduce this through the 14.0.2 compiler, but not in the beta version of the release planned for later this year.
There's nothing wrong with your use of the DATA statement. You can create a parameter constant of derived type, like this:
type (mytype), parameter :: te = mytype(array=[1.d0, 1.d0, 1.d0, 0.d0, 0.d0, 0.d0])
