29486 Discussions
Strange behavior in f77 subs using V9
pecan204
Can someone please comment.
I converted an older workspace in CVF to IVF. All compiles but when running I get unexpected behavior when calling a couple of subroutines. I have now spentdays debugging these two issues.
The first is: After second call to the function THERM it does not recognize data fa = -1.0. I later added the the FA=. Now it works. But why did it not work consistently before?
FUNCTION THERM (ID,ARG,FAOLD,DUMMYP)
IMPLICIT DOUBLE PRECISION (A-H,O-Z)
DATA FA/-1.D0/
X=ARG
FA = -1.0
The second is:After the second call to sub flocal the variable n1 changes to 10. What is doing this and what else can I inspect to see why and fix it?
SUBROUTINE FLOCAL (IGET,SS,EROR,JCXCNT)
IMPLICIT DOUBLE PRECISION (A-H,O-Z), INTEGER (I-N)
As soon as the second call enters sub here, N1 changes to 10. The first call it was set to 1 seen below. The second pass imediately changes to 10 without being set by a variable.
DO 10 I=1,NTBL
IF(ITAB(I).EQ.6969)IBOATTAB=I
10
CONTINUE
IF (NPASS.LE.0) THEN
XPASS=.FALSE.
N1=KKINDS(1,1)
Thanks for any help.
Ken
jimdempseyatthecove
Ken,
I am not sure on your 1st question, but for the second question it would seem that you are expecting N1 to have been saved from the prior call to FLOCAL. To have persistance you need to declare N1 with the SAVE attribute (or compile with /Qsave to save all variables).
Your first question error may also be corrected with /Qsave.
Also, consider using in THERM
REAL(8), SAVE :: FA = -1.D0
And using in FLOCAL
INTEGER, SAVE :: N1 = (initial N1 to 0, -1, 9999, whatever)
Since your programhas problems of uninitialized variables (not saved), you may find it fruitful to compile and debug with the runtime check for uninitialized variables.
Jim Dempsey
Les_Neilson
Valued Contributor II
Ken,
First, all of your "debug" configurations shouldhave all of the warnings set on, especially bounds checking. The problem with variable FA sounds suspiciously like an out of bounds overwite of memory somewhere.
The problem with N1 : If N1 is a local, unsaved variable of subroutine FLOCAL then it will be allocated storage automatically on entering FLOCAL, the contents of that storage will be whatever is in there at the time - there is no automatic initialisation of variables. If the first thing you do with N1 is an assignment to itthen the previous contents are immaterial.
hth
Les
pecan204
Thank you Les/Jim, Very informative answers. I'll try that right now.
I also just used the locals view and see there is a N1STT equal to 10 that is comming from an include common block. But how could it be written to N1? There is no equivalence.
Les_Neilson
If N1 is truly independent of N1STT then it is just coincidence.
One of the problems of common blocks is out-of-bounds errors. An array in one common with some code "array(I) = something"where the value of I is out of the bounds of the array could overwrite data either in the same common block or in the next common block.
Most of us "older" programmers will have seen this before.
Les
You have a coding error not apparent in the snippets you post. I suggest enabling "Generate Interface Blocks" (/gen-interface) and "Check Interface Blocks" (/warn:interface) to see if there are calling mismatches.
pecan204
Thanks Steve,
I did have success in getting it running with /Qsave and now to your recomendation I am looking for an interface error. /gen-interface and /warn came up with an error calling a charcter function with the *. But I am not that familiar with that call. Do you know what is the correct way?
Function below.
Ken
CHARACTER *(*) FUNCTION SHIFTBL(CHSTR)
CHARACTER *(*) CHSTR
INTEGER I, J
J=1
DO I=1,LEN(CHSTR)
IF (CHSTR(I:I).EQ.' ') THEN
ELSE
CHSTR(J:J) = CHSTR(I:I)
CHSTR(I:I) = ' '
J = J + 1
ENDIF
ENDDO
SHIFTBL = CHSTR
RETURN
END
You don't show the call. However, I do know that the /gen-interface can't create an interface for a function returning CHARACTER(*) as that's not allowed in the language. This should not give an error, though - just a warning.
Functions returning CHARACTER*(*) are no longer standard Fortran and are considered bad practice, as the length depends on how you declare the function in the caller.
Dishaw__Jim
Out of curiosity, what is the approved solution for returning a string. Lets consider a function that takes a string as an argument and will return the upper case version of it without modifying the original string (the input argument is INTENT(IN) and not INTENT(INOUT)).
anthonyrichards
New Contributor III
I always use
length=len_trim(string)
call sub(string,length)
Subroutine string (string,length)
integer length
character string(length)
and ALWAYS ensure thatI do not go beyond 'length'
when processing the string.
In Fortran 90 you can do something like this:
function myfunc (arg) result (res)
character(len=*), intent(in) :: arg
character(len(arg)) :: res
This does require an explicit interface (putting it in a module will do it.)
