29434 Discussions
Strange bug with different method of adding
Wee_Beng_T_
I have a CFD code whereby in a subroutine, I have to calculate the angle theta_x_rad. I calculate it using:
theta_x_rad = - 0.5d0*omega_r_max*(tmp_time2 - (0.5d0*dt_r/Pi)*sin(2.d0*Pi*(tmp_time2 + 0.5d0*dt_r)/dt_r)) + k_r1 (= 1.57, given by print)
theta_x_rad = - theta_x_rad + Pi
I got the correct ans, which is ~1.569. Now if I do it in this way:
theta_x_rad = 0.5d0*omega_r_max*(tmp_time2 - (0.5d0*dt_r/Pi)*sin(2.d0*Pi*(tmp_time2 + 0.5d0*dt_r)/dt_r)) + k_r1 + Pi (no minus sign in front)
I got 4.71. It seems that the 1st term above is calculated as 1.57 instead of -1.57
I tried different intel versions, debug, opt etc, but the ans are the same.
Did I miss out on something?
mecej4
Check the sign of the term k_r1 in the line on which you commented "no minus sign".
Wee_Beng_T_
Hi mecej4,
It's a predefined variable and it's ~ 1.57. I checked too.
mecej4
Here is the clarification of my comment, which was about the expression and not the declaration or definition of k_r1.
The + sign attached to k_r1 is not consistent with what you get from combining the two preceding assignment statements in your original post. Algebra rules say that you should have written - k_r1 instead.
I suspect that the leading term is negligibly small. If so, the three statements in questions could be written as follows:
    theta_x_rad =  + k_r1
    theta_x_rad = + k_r1 + Pi  <<<=====  Error: the first '+' should be '-'
If k_r1 is close to π/ 2 (≈ 1.57), the first two statements taken together yield the result π/2, whereas the third, because of the erroneous sign, yields 3 π / 2 (≈ 4.71).
In other words, the culprit is an error in algebraic simplification and not anything involving programming, Fortran, or compiler options.
Wee_Beng_T_
Hmm, still don't really understand. I'll check with some other values and get back to you.
mecej4
Well, let's try something different. The two sequential assignments
   x = -a + b
   x = -x + c
cause x to have the final value a - b + c
Your third assignment (the alternative), on the other hand, causes x to have the value a + b + c. The second term in this "result" has an incorrect sign.
That is the crux of the matter, and you really do not need to try different values, etc.; simply recollect and apply the rules of algebra.
Wee_Beng_T_
Ops ... I saw it!
It should be:
x = a - b + c, but I gave it x = a + b +c !
It's so embarrassing. I just can't see it intially... Thanks again!
