29593 Discussions
Strange compiler behavior for very old program
Mike_Z_
What's wrong in following (from 70th) code?
      1       PROGRAM CFDUE
      2 !      IMPLICIT REAL (A-C,E-H,O-Z), INTEGER (I-N)
      3       INTEGER I,K
      4       REAL P,TR,X,Y,R,AL,T54,T56,T55,T1,REK,AIMK,Z,W,T
      5 !      DIMENSION Q(100),R(50),P(10)
      6       COMMON/AB/Q(100),R(50),P(10)
      7       COMPLEX Q,D,D1
      8       OPEN (7, FILE='D30.DAT')  !
      9       OPEN (6, FILE='CYLT.LST') !
     10 !      COMPLEX Z,W
     11       DATA(P(I),I=5,8) /0.2000001,0.00000001,4.,2./     !
     12       TR(X,Y)=COS(X/3.)*(R(5)-Y*R(49))-SIN(X/3.)*REAL(Q(3))
 ......1
(1) This name has not been declared as an array or a function.   [TR]
     13       AL(T)=R(6)/(R(49)*(P(1)+(10.**(-17.)))*COS(R(15)))+T
 ......1
(1) This name has not been declared as an array or a function.   [AL]
     14       T54(Z)=ABS(Z)-(10.**(-5.))
 ......1
(1) This name has not been declared as an array or a function.   [T54]
     15       T56(Z)=ABS(Z)-0.00000001
 ......1
(1) This name has not been declared as an array or a function.   [T56]
     16       T55(Z)=ABS(Z)-R(50)
 ......1
(1) This name has not been declared as an array or a function.   [T55]
     17       T1(Z)=ABS(Z)-R(40)
 ......1
(1) This name has not been declared as an array or a function.   [T1]
     18       D(W)=CEXP((-2.,0)*R(49)*Q(9)*Q(10)*W)
 ......1
     19       D1(W)=(D(W)-1.)/(D(-1.)-1.)
 ......1
(1) This name has not been declared as an array or a function.   [D1]
     20 !   1 READ 1001,(P(I),I=1,4)                               !
     21     1 READ (7,1001,end=2000),(P(I),I=1,4)                  !
     22  1001 FORMAT(4F14.8)                                       !
     23       PRINT 1002,(P(I),I=1,4)                              !
     24  1002 FORMAT(///10X,' 22HMODNU,ARGNU,MODZ,ARGZ=',4F14.8)   !
     25       DO 14 I=1,10
     26       R(30+I)=0.
     27    14 CONTINUE
Also, program couldn't fully compiled: Compilation Aborted (code1)
You have two OPEN statements in the middle of the declaration section, which is illegal. The TR(X.Y)= line is a statement function, which is not allowed to be in the executable section. Move those OPEN statements to after all the declarations. This code would never have compiled with any compiler I am familiar with.
Mike_Z_
Thanks a lot, Steve!
