Strange problem with Static Library
cesarpradosboda
I want to make a small program that uses a static library made in FORTRAN&C, to see how the calls workfrom Fortran to functions made in C when I want work whit Build Environment for EM64T-based applications, I've made this:
LIBRARY
Code:Lib_c_64.h
#include
#include
#include
#include
#include
int write_hello();
Code:Prog_c_64.c#include "Lib_c_64.h"
int write_hello()
printf("Ciaooooooo");
return 0;
Code:Prog.f90
SUBROUTINE WRITE_SM()
INTERFACE
INTEGER FUNCTION write_hello()
!DEC$ ATTRIBUTES C,ALIAS:'write_hello'::write_hello
END FUNCTION
END INTERFACE
INTEGERIO
IO = write_hello()
RETURN
END SUBROUTINE WRITE_SM
the library is created, I introduce it in the directory of the program that will used it, and "add existing item", the program that uses the library:
Code:Program.f90
 program Programi
 implicit none
CALL WRITE_SM()
 end program Programi
result:
Program fatal error LNK1120: 1 unresolved externals
Program error LNK2019: unresolved external symbol write_sm referenced in function MAIN__
I have controlled how the call is made, I've watched .lib with Dumpbin.exe and it makes it of this form:
   1 public symbols
        1 WRITE_SM
                                               Symbol    Symbol
 Offset    Type              Applied To         Index     Name
 0000000B  REL32                      00000000         C  write_hello
TheCOnfiguration Properties:
Disable Default Library Search Rules: NO
Calling Convention:C,REFERENCE
Name Case Interpretation:
if is Lower Case-->
if is Upper Case-->
Program error LNK2019: unresolved external symbol WRITE_SM referenced in function MAIN__
What do I make wrong?
jim_dempsey
Try one of two options:
Option 1) In the "project" that contains Programi open the properties page and check the depends on box for the library you created.
Option 2) In the linker properties, input page, Additional Dependencies add your library name there.
Jim Dempsey
