29341 Discussions
Strange segfault with OpenMP and iso_c_binding
Lars_Pastewka
Dear community,
I encountered weird behavior which may be a compiler bug. The following code segfaults if compiled with "-openmp".
[fortran]
module test_mod
  type test2_t
    integer :: f = 3
  endtype test2_t
  type test_t
    type(test2_t), allocatable :: a
  endtype test_t
contains
  subroutine test_func(test_cptr) bind(C)
    use, intrinsic :: iso_c_binding
    type(C_PTR), value :: test_cptr
    type(test_t), pointer :: test
    call c_f_pointer(test_cptr, test)
    if (.not. allocated(test%a)) then
      allocate(test%a)
    endif
endsubroutine
endmodule test_mod
program test_prog
  use test_mod
  type(test_t), target :: test
  call test_func(c_loc(test))
endprogram test_prog
[/fortran]
From the compilers I have available, the code sefaults with ifort 11.1 20101201 and 12.1.3 20120212, but does not with ifort 11.0 20081105 and ifort 12.0.0 20101116.
The code does not segfault if (all tested with ifort 12.1.3 20120212)
  • compiled without "-openmp"
  • module and program are placed in a single file
  • the "if allocated(...) then" statement is removed
  • the default value (= 3) in test2_t is removed
From debugging the code it looks like memory allocation works and the code the produces the segmentation fault when copying the default data.
Not sure what's going on here. I think it may be a compiler bug. Or is there something obvious I'm doing wrong?
Many thanks,
Lars
I can reproduce this in versions as late as 12.1.5, but nothing more recent than that (13.0, etc.). I suspect it is a compiler bug that got fixed.
Lars_Pastewka
Okay, thanks for that information. I see if we can update.
