29382 Discussions
Stunned! Gfortran 4.5 produces faster code on new Imac than Intel 11.1
Greynolds__Alan
Just got my new Imac with a 3.33Ghz Core 2 Duo processor. So far all tests of my application show that the Gfortran 4.5 compiled version is ~25% faster than the Intel 11.1.067 compiled version. Has anyone else seen this surprising result?
With Intel I used the -fast option while for Gfortran I used the following:
-O3 -funroll-loops -march=native -ffast-math -mfpmath=sse -msse4.1 -ftree-vectorizer-verbose=1
The results of the calculations appear to be the same within expected FP accuracy and roundoff.
Al Greynolds
TimP
On individual benchmarks with Fortran 95 syntax, loop length 100 and greater, on Core i7, I see gfortran 4.5 varying from 15% to 300% of the speed of ifort 11.1. Sticking to f77 code, ifort consistently out-performs gfortran on the same benchmarks.
gfortran performs extremely aggressive unrolling with the options you quote. On Core i7, it has to be limited to unrolling by 4 to show full performance, although the extra unrolling should gain on your Core Duo when your loop lengths match the unrolling.
In general, you would require ifort standard compliance options -assume protect_parens,minus0 -prec-div -prec-sqrt to see satisfactory accuracy comparisons with gfortran.
gfortran -ffast-math does introduce some optimizations which are equivalent to ifort defaults.
It doesn't make much sense to quote a comparison with no context. It's certainly possible that you have applications which hit the weaknesses of ifort, but not those of gfortran. If you can make a case for their importance, you have the choices of showing them here or filing issues on premier.intel.com. Specifically, where gfortran vectorizes successfully and ifort doesn't, a simple test case would be useful.
