29649 Discussions
Subroutine with undefined input variables
jaeger0
Hi
I'm writing a Subroitine to proof the validity of certain variables. If they exceed the limit, then a warning, or error is given.
Further the values are restricted set to its max/min range.
Subroutine Proof_values(value, range, exceeding)
type(t_range) range
! input/output
integer(4) value
! output
integer exceeding
exceeding = 0
if (value .GT. range%max) then
exceeding = 2
value = range%max
endif
So I have different types of variables Integer2..8, real4..8
I don't want to write the subroutine for each of the different datatypes, so is there a posibility to apply the subroutine for
the different datatypes ?
onkelhotte
New Contributor II
Quoting - jaeger0
Hi
type(t_range) range
! input/output
integer(4) value
! output
integer exceeding
exceeding = 0
exceeding = 2
value = range%max
endif
Unlike C++/C#/Java... where you can overload methods, Fortran does not have such a feature.
What you can do is to build your subroutine with a kind=8 type and when you use it, you useint8 or real8 to convert it to the required type.
Markus
jaeger0
Quoting - onkelhotte
Markus
ok I see,
but, lets set
real(kind=8) value
and then
integer(2) age
call Proof_values(dble(age), ...)
this will pass the input value correctly, but not the output value. If I internally set
the value, then it is not passed to the output correctly
I don't want to change all variables to real(8) for generality.
I re-wrote the subroutine to
Proof_values(value,out_value, ..)
outvalue= value
out_value = range%max
call Proof_values(dble(age),out_val, ..)
age = outval
But this does not look nice !!
Is there any other possibility ?
Les_Neilson
Valued Contributor II
Quoting - jaeger0
You could take a look at generic procedures (subroutines or functions) (see in the help).
All of your calls in the rest of the codewould be to the generic name, and the arguments would determine which specific routine is actually called. You would have to write the specifics for each type (integer, real, etc) but onlyneed to do it once.
Les
jaeger0
Quoting - Les Neilson
Les
I think I understand the help/example. However I don't really understand how to systax it.
For the example
I get the error "the type of actual argument differs from the type of dummy" for line "call proof(a, 2)"
Furter I want tho have a Type variable, but this is not possible in the Interface
Any suggestions ??
module PROOF
contains
subroutine proof(val,thr)
interface
subroutine real8_sub(val,thr)
real(8) val,thr
end subroutine
subroutine int4_sub(val,thr)
integer(4) val,thr
end subroutine
! subroutine int_sub(val,thr)
! integer(4) val
! type(Dlg_ValueRange) no types allowed ??
! end subroutine
end interface
if (val .GT. thr) val=thr
end subroutine
end module
program TEST
USE PROOF
integer a
real b
call proof(a, 2)
call proof(b, 3.5)
end
jimdempseyatthecove
proof is declared with an interface using "integer(4)" but is being called with arguments of "integer"
Jim Dempsey
jaeger0
Jim Dempsey
I changed the input datatype to integer(4) => Same error
jimdempseyatthecove
"2" is "integer" not "integer(4)". Try "2_4"
Jim
jaeger0
Jim
I understand, but the error remains
integer(4) a,c
call Proof(a,c) => Err1 "the type of actual.. ..argument ; Err2 "the ..argument
call Proof(a,2.5) => Err1 "the type of actual.. ..argument
call Proof(1.0, 2.5) => no Error !!
something else is maybe wrong
First of all, INTEGER is INTEGER(4) by default and 2 is the same as 2_4 by default.
The real problem is that you have not written a generic interface, plus you are passing REAL(4) arguments but have defined only a routine that accepts REAL(8). Here's an example that works (ignoring for now that val is uninitialized in each of the calls).
[plain]module PROOF_MOD
interface proof
module procedure real4_sub
module procedure real8_sub
module procedure int4_sub
end interface
contains
subroutine real4_sub(val,thr)
real(4) val,thr
end subroutine
real(8) val,thr
end subroutine
integer(4) val,thr
end subroutine
end module
program TEST
USE PROOF_MOD
integer a
real b
call proof(a, 2)
call proof(b, 3.5)
end[/plain]
You can't give the same name to a module and a generic procedure so I renamed the module.
