Support __FUNCTION__?
GHui
Does intel fortran support __FUNCTION__ to get function or subroutine name?
GHui
Thecodeasfollowing,
-----1.f------------
programmain
print*,__FILE__,__FUNCTION__
endprogram
Iexpectthatitwilloutput"1.fmain".
Any help will be appreciated.
Georg_Z_Intel
from top of my head, no. The only supported directives for FPP are:
Directive Result
__FILE__ replace this string with the input file name (a character string literal)
__LINE__ replace this string with the current line number in the input file (an integer constant)
__DATE__ replace this string with the date that fpp processed the input file (a character string literal in the form Mmm dd yyyy)
__TIME__ replace this string with the time that fpp processed the input file (a character string literal in the form hh:mm:ss)
Usually providing both file name & line number should be sufficient to identify a source location.
Georg Zitzlsberger
TimP
This was only today filed as a feature request for gfortran
If it were supported in the pre-processor for another Fortran, such a pre-processor could be used. fpp tends to avoid extensions beyond widespread practice.
