Switching from IFORT to IFX
Andrew_Smith
Valued Contributor I
Why is the Intel Compiler sub-menu greyed out when right clicking on a Fortran project? I cant find how to switch to IFX. I have VS 2022 17.11.6 and IFX 2024.2.1, IFORT 2021.12.0
Andrew_Smith
I did have un-used 32 bit configurations in the project file. I removed these and its re-enabled the compiler choice menu
Steve_Lionel
Are you in a 32-bit configuration? ifx is 64-bit only.
Andrew_Smith
I am using 64 bit.
I was able to edit the project file in notepad to get IFX setting.
Andrew_Smith
