29604 Discussions
Tab Stops in Dialog List Box Properties
wiland
In the Styles tab of the Dialog List Box Properties is an optionthat allows using tabstops in strings that are written to the list box. The description in "Help" states:
Use tabstops - Allows a list box to recognize and expand tab characters when drawing its strings. The default tab positions are 32 dialog box units (DLUs). Type: Bool. Default: False.
Can anyone tell me how to change the default tab positions? Is there some Dialog control that does this?
Bruce
Jugoslav_Dujic
Valued Contributor II
You have to send it LB_SETTABSTOPS message. See herefor an example. Note that you will have to experiment a little with values of tab stop positions as they're expressed in DLU-s; best, use char(9)//"|"//char(9)//"|"... as a test string.
Jugoslav
wiland
Thanks Jugoslav. It worked great.
Bruce
