Table in a dialog
meistrv
I would like to make a small dialog based application for handling database (with the help of f90SQL from CanaimaSoft). What I need is to put a table (spreadsheet - with fixed number of columns and variable number of rows) on the dialog for viewing and inserting records. Is there any such control? Or would I have to use something like ActiveX control?
Thank you for any suggestions
Vit Meistr
Jugoslav_Dujic
Valued Contributor II
Jugoslav_Dujic
...oh, I forgot that Xeffort now supports ListView controls :-). If you don't need full user-editable capabilities, that might be the easiest solution.
See LVTest sample on Xeffort.com; (you have to download and install the library first to build it). Usage of ListView controls is well documented under XFTCtrl chapter.
Jugoslav
