Temporary copy of an array on WRITE
Jugoslav_Dujic
Valued Contributor II
I'm not sure if this deserves a bug report, but I'd like to pay attention to it here. CVF 6.6B (and 6.6A) generates a temporary copy of an ALLOCATABLE array on WRITE to a binary file. The following causes a stack overflow on WRITE:
PROGRAM Test
INTEGER(1), ALLOCATABLE::  bits(:)
ALLOCATE(bits(1100000))
!INTEGER::  bits(1100000)
OPEN(11,FILE="Test.bin",FORM="Binary")
WRITE(11) bits(1:1100000)
CLOSE(11)
END PROGRAM
Stack overflow does not occur if the array is static; it does not occur when the array triplet (1:1100000) is ommitted either.
(If you've downloaded XFTGDI from my web page, this will happen on XSaveBitmap for a moderately large bitmap)
Jugoslav
I've seen that... Omitting the subscript range is, as you note, the obvious alternative. It's already on our list to look at for future improvements.
Steve
grtoro
I just found out the the problem also happens (in 6.6B) when doing a binary write of LARGE_STRUCTURE(1:N), even if the structure is allocated statically. Annoying!
Gabriel
Jugoslav_Dujic
An implied do-loop instead of array section is a workaround if I recall correctly.
Annoying :-(.
(I didn't test it on latest IVF though.)
Jugoslav
