Test.obj fatal error LNK 1136
postaquestion
I urgently need your help to solve the following problem, which occurs when trying to run your Intel Fortran Compiler 9.1 with a file test.f:
test.obj : fatal error LNK1136: invalid or corrupt file
I hope, you will answer soon. Thank you in advance.
Did the compile phase complete without errors? The error you show suggests that the compilation failed in an unusual way.
If you need urgent help, PLEASE submit an issue to Intel Premier Support and attach the necessary files to reproduce the problem.
