29386 Discussions
The application for project C:\\...\\*.vfproj is not installed
cbjiang
I had Intel Visual Fortran 9.1 and .net 2003. My projects were created in MS .net 2003. The .net solution has both C++ and fortran projects in it. This configuration worked fine on my old computer (XP). However, after installing .net 2003 and Visual Fortran 9.1 on my new XP computer, the same fortran projects can not be loaded anymore. The error message is: The application for project C:\\...\\actch.vfproj is not installed. Make sure the application for the project type (.vfproj) is installed. The Intel Fortran 9.1 compiler is in fact installed.
Do you have any idea whats wrong? What should I do?
Thank a lot,
Uninstall the compiler and reinstall. If that doesn't help, I'll give you instructions for a manual repair. There's a repair tool in a Knowledge Base article but it doesn't work on 9.1.
cbjiang
Thanks, Steve.
I think I figured out the problem: in addition to the Intel Fortran 9.1 Compiler, one also need to installthe integrator (IDE) that goes with Intel Fortran. It fixed my problem any way.
Thanks a lot for your help
