29369 Discussions
The maximum length of processor collating sequence
DataScientist
Valued Contributor I
The Fortran standard `char (i [,kind] )` returns the character in position i in the processor collating sequence associated with the relevant kind parameter. The value of i must be in the range `0 < i < n - 1`, where n is the number of characters in the processor’s collating sequence. Is there a way to infer the value of `n` in a portable way within the programming environment?
Steve_Lionel
@DataScientist wrote:
What would `char(i)` behavior be if the collating sequence can be discontiguous?
Undefined.
I'll admit that I was not familiar with the behavior of MAXVAL/MINVAL when ARRAY is size zero. It would seem that:
ichar(minval(c))
where c is a zero-sized array of characters, does what you want.
Steve_Lionel
Interesting question. I can't think of a reasonable way, offhand. What's your use case? I think some character sets have discontiguous ranges, which could complicate matters.
DataScientist
The goal is to replicate `minval`/`maxval` and similar functionalities for scalar character sequences.
These two intrinsics return the maximum/minimum of the corresponding type and kind if the input array has zero size.
For characters, the result of the comparison is determined by the positions in the processor collating sequence.
Therefore, the last character in the collating sequence is required to fully mimic `minval`/`maxval` behavior.
Steve_Lionel
Undefined.
ichar(minval(c))
DataScientist
DataScientist
I also have to admit that I did not know `minval` and `maxval` work with character arrays.
