29642 Discussions
Tools for detecting corrupted memory
Martin__Paul
Can you recommend any tools for checking memory for corruptions, e.g. uninitialized variables, buffer overruns, etc? I am familiar with the static verifier but its usefulness seems to be limited by the large number of false positives returned.
Les_Neilson
Valued Contributor II
Well the compiler itself comes withrun-time diagnostics that help identify uninitialised variables and array and string bounds errors.
I have heard ofa memory toolcalled HeapWalker, but I have never used it.
Les
Wendy_Doerner__Intel
I think Les is referring to the /check compile time switch in the compiler. It will add runtime checks for the things you mention.
Wendy
Attaching or including files in a post
