29657 Discussions
Traceback information available for processing in a program
albert
Dear all,
With the function tracebackqq it is possible to obtain a stack trace writen to ones output. I need to have the information not in my output but I want to use it in my program (to see from where a certain routine is called. i.e. filename and linenumber).
Is there a way to obatin this information ?
Albert
You can use an environment variable to have the output written to a file by derfining the environment variable FOR_DIAGNOSTIC_LOG_FILE to point to where you want the info written. Then you can open the file and read it.
mecej4
It would be nice to have such information available in the documentation. I searched for the name of this variable in
http://software.intel.com/sites/products/documentation/hpc/composerxe/en-us/fortran/lin/index.htm
and found nothing.
albert
Hi Steve,
This will, unfortunately, not work in my case:
- it is a MPI process, so it is possible that multiple processes will write to the same file (well in my case I think it is certain, I could set the environment variable which might solve this problem) .
- the routine that has to use the information is called very often (order millions of times in a couple of hours), so my processes would come to a crunching halt.
Albert
The variable is not indexed in its own name, but is in the list under Environment Variables > Run-Time.
