Traceback information is missing
lccostajr
I am compiling my Fortran application with the following set of parameters:
-nologo -c -assume:byterecl -fpp -gen-interfaces:nosource -warn:interfaces /MT  -check:all -Qfp-stack-check /traceback -fpe0 /debug:all
However, when the application crashes, I am getting the following output:
forrtl: severe (408): fort: (3): Subscript #1 of the array MYARRAY has value -858993460 which is less than the lower bound of 1
Image              PC        Routine            Line        Source
myapp.exe          025CE6E0  Unknown               Unknown  Unknown
myapp.exe          02565876  Unknown               Unknown  Unknown
myapp.exe          02526582  Unknown               Unknown  Unknown
myapp.exe          02526CF3  Unknown               Unknown  Unknown
myapp.exe          021BE6B0  Unknown               Unknown  Unknown
myapp.exe          021CC278  Unknown               Unknown  Unknown
myapp.exe          02285467  Unknown               Unknown  Unknown
myapp.exe          022A61AC  Unknown               Unknown  Unknown
myapp.exe          022794C7  Unknown               Unknown  Unknown
myapp.exe          01828FB8  Unknown               Unknown  Unknown
myapp.exe          024CE0DA  Unknown               Unknown  Unknown
myapp.exe          025D0353  Unknown               Unknown  Unknown
myapp.exe          025A756F  Unknown               Unknown  Unknown
kernel32.dll         76EA33AA  Unknown               Unknown  Unknown
ntdll.dll               77899EF2  Unknown               Unknown  Unknown
ntdll.dll               77899EC5  Unknown               Unknown  Unknown
where I was expecting to see routine names and line numbers.
What am I doing wrong?
The version of my compiler is:
Intel(R) Visual Fortran Compiler XE for applications running on IA-32, Version 13.1.0.149 Build 20130118
Copyright (C) 1985-2013 Intel Corporation. All rights reserved.
Thanks in advance,
Luiz
mecej4
Check if the linking command (e.g., ifort without the /c option) included the /traceback option.
lccostajr
That was the problem, now its is working.
Thanks for your prompt reply.
Luiz
