Trapping on uninitialized variable use
Scott_L_
Using the compiler option to initialize variables to Nan and trap on Nan (uninitialized variable), should this trap on assigning an uninitialzed variable to another variable, or just using it in an arithmetic expression?
When  y is NaN and uninitialized, I don't seem to get an exception with
x = y
but I do for
x = y + 1.0
thanks,
Scott
Steven_L_Intel1
Note that in the current version, only static (SAVEd) variables get initialized. I tried a toy program and got the error. Optimization might do something to the assignment that prevents the error from happening.
mecej4
How the statement x=y is executed may depend on the compiler options used. It is conceivable that copying bytes could be done using purely integer instructions, rather than loading and storing an FPU register (XMM or X87). If so, the NaN would not be caught.
The following program, compiled using /warn:uninit /auto with the 15.0 64-bit compiler, did report a runtime check failure on the third line.
program uninit
real x,y,z
x=y
z=y+1.0
write(*,*)x,y,z
end program
Scott_L_
I am compiling in debug &  noopt.  The variable y in my real application is static in the main program, and passed as an argument to a subroutine.  In the subroutine, x = y does not trap but x = y - something does not.
Steven_L_Intel1
An example would be helpful. Here's what I tried:
C:\Projects>type t.f90
program test
real x,y
y = x
print *, y
end
C:\Projects>ifort /Qinit:snan /Qsave t.f90
Intel(R) Visual Fortran Compiler XE for applications running on IA-32, Version 15.0.1.148 Build 20141023
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
Microsoft (R) Incremental Linker Version 12.00.31101.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:t.exe
-subsystem:console
t.obj
C:\Projects>t.exe
forrtl: error (65): floating invalid
Image              PC        Routine            Line        Source
t.exe              0128F359  Unknown               Unknown  Unknown
ntdll.dll          77AC389A  Unknown               Unknown  Unknown
ntdll.dll          77AC3492  Unknown               Unknown  Unknown
ntdll.dll          77ACBC5B  Unknown               Unknown  Unknown
ntdll.dll          77AC01BB  Unknown               Unknown  Unknown
ntdll.dll          77AD0E6B  Unknown               Unknown  Unknown
ntdll.dll          77ABF55E  Unknown               Unknown  Unknown
ntdll.dll          77ABF5EC  Unknown               Unknown  Unknown
C:\Projects>
However, further analysis shows that the error occurs on the print, not the assignment,. Looking at the assembly I see that movss instructions were used to move the data. This doesn't trap on a floating invalid.
Scott_L_
main:
program checknan
real :: y
call sub(y)
stop
end program checknan
in sub.f90:
subroutine sub(y)
real, intent(inout) :: y
real :: x,z
x = y
print *,' set x '
z = y + 1.0
print *,' set z '
return
end subroutine sub
I set this up quickly and compiled in Debug/x64  with Yes (/Qinit:snan)  and Yes (/Qinit:arrays).
Maybe I did something wrong because it did not trap on either use of y.
Steven_L_Intel1
C:\Projects>t.exe
  set x
forrtl: error (182): floating invalid - possible uninitialized real/complex variable.
t.exe              00BA10EB  _SUB                       22  t.f90
t.exe              00BA1039  _MAIN__                     5  t.f90
t.exe              00BD8092  Unknown               Unknown  Unknown
t.exe              00BD87F5  Unknown               Unknown  Unknown
kernel32.dll       75BF338A  Unknown               Unknown  Unknown
ntdll.dll          77ACBF32  Unknown               Unknown  Unknown
ntdll.dll          77ACBF05  Unknown               Unknown  Unknown
You need to add /Qsave.
Scott_L_
Thanks.  So it is printing "set x" after executing x = y, which must not be generating an exception.   It does generate an exception at z = y+1.0.   So it is when the saved NaN is used in an expression that you see the break.
thanks
jimdempseyatthecove
There are two types of NaN: signaling (SNaN) and non-signaling (QNaN) iow Quiet NaN
When a signaling NaN (SNaN) is used in a floating point instruction it will generate an exception. However, if the memory location holding the floating point SNaN is manipulated using general purpose registers (i.e. integer) then an exception will not be generated. A statement like x=y can be executed using general purpose registers (as well as through use of FPU, SSE, AVX floating point instructions). Also note that it is possible for a statement such as IF(X .EQ. Y) to perform an integer bit-wise compare depending on compiler options.
For this reason, you may need to trace back several statement, and/or call levels to find the source of the NaN (most often due to bad programming).
Jim Dempsey
