Maybe there is a trick I am not aware of...
Assume I need my code to write a text file which content is fixed (say, a template file, or a mini help file) and which will not be modified by the code execution. The obvious solution is to create a subroutine with as many WRITE statements as there are lines of content to be produced. This becomes quickly cumbersome for larger files. Is there a workaround for this?
Olivier
Why not have some template files in the program folder and just get the program to copy the file? If it is s windows appliocation there is an sdk copyfile function interface in ifwin.
http://msdn.microsoft.com/en-gb/library/windows/desktop/aa363851(v=vs.85).aspx
You could just have the code call EXECUTE_COMMAND_LINE to make a copy of the file, or a pair of READ and WRITE statements in a loop could copy it, possibly with a TRIM. If you don't want your original file to have to be present for the executable to work, you could use the resource compiler to include the original in your executable then READ and WRITE the copy in a loop again.
Thanks - I will look into the resource compiler idea, as the original file(s) cannot be stored independently from the executable.
If you initialize your fixed content in a (large) DATA statement as an array of lines, eg
INTEGER, PARAMETER :: numlines =1234
CHARACTER(LEN=80),DIMENSION(numlines) :: helptext
CHARACTER(LEN=2), PARAMETER :: crlf = CHAR(13)//CHAR(10)
DATA helptext (/"line1 ", &
"line 2 ", & ! and so forth
" lastline "/)
then you can send your text to a file with only a single WRITE statement:
OPEN(3,FILE='HELPFILE.TXT', STATUS=NEW)
WRITE (3,'(10000A)') ((helptext(j)(1:LEN_TRIM(helptext(j)), crlf), j=1, numlines)
CLOSE(3)
Just for fun I wrote out a working example with gfortran. It will be slightly different with ifort -- let the other users show us the adjustments.
The input file, MyFile.txt:
Here is MyFile.txt This is line 2 This is line 3
Since gfortran doesn't come with ifwin, we need to create our own ifwin.f90:
module ifwin use ISO_C_BINDING use ISO_C_BINDING, only: HANDLE => c_intptr_t use ISO_C_BINDING, only: DWORD => c_int32_t private public HANDLE, DWORD public GetLastError interface function GetLastError() bind(C,name='GetLastError') import implicit none !gcc$ attributes stdcall :: GetLastError integer(DWORD) GetLastError end function GetLastError end interface public FindResource interface function FindResource(hModule,lpName,lpType) bind(C,name='FindResourceA') import implicit none !gcc$ attributes stdcall :: FindResource integer(HANDLE) FindResource integer(HANDLE), value :: hModule character(kind=C_CHAR) lpName(*) character(kind=C_CHAR) lpType(*) end function FindResource end interface public LoadResource interface function LoadResource(hModule,hResInfo) bind(C,name='LoadResource') import implicit none !gcc$ attributes stdcall :: LoadResource integer(HANDLE) LoadResource integer(HANDLE), value :: hModule integer(HANDLE), value :: hResInfo end function LoadResource end interface public SizeofResource interface function SizeofResource(hModule,hResInfo) bind(C,name='SizeofResource') import implicit none !gcc$ attributes stdcall :: SizeofResource integer(DWORD) SizeofResource integer(HANDLE), value :: hModule integer(HANDLE), value :: hResInfo end function SizeofResource end interface public LockResource interface function LockResource(hResData) bind(C,name='LockResource') import implicit none !gcc$ attributes stdcall :: LockResource type(C_PTR) LockResource integer(HANDLE), value :: hResData end function LockResource end interface end module ifwin
Then we need a simple txtresource.rc:
MyFile 256 MyFile.txt
And here is Fortran source code that can use the above, txtres.f90:
program txtres use ifwin use ISO_C_BINDING implicit none integer(HANDLE) res_HRSRC integer(HANDLE) res_HGLOBAL integer(DWORD) res_Size type(C_PTR) res_LPVOID character(len=:,kind=C_CHAR), pointer :: fptr integer iunit character (80) filename integer(C_INTPTR_T) int_lpType type(C_PTR) C_lpType character(kind=C_CHAR), pointer :: lpType int_lpType = 256 C_lpType = transfer(int_lpType,C_lpType) call C_F_POINTER(C_lpType,lpType) res_HRSRC = FindResource(0_HANDLE,'MyFile'//achar(0),lpType) if(res_HRSRC == 0) then write(*,'(a,i0)') 'FindResource failed with error code ',GetLastError() stop end if res_HGLOBAL = LoadResource(0_HANDLE,res_HRSRC) if(res_HGLOBAL == 0) then write(*,'(a,i0)') 'LoadResource failed with error code ',GetLastError() stop end if res_Size = SizeofResource(0_HANDLE,res_HRSRC) if(res_Size == 0) then write(*,'(a,i0)') 'SizeofResource failed with error code ',GetLastError() stop end if res_LPVOID = LockResource(res_HGLOBAL) if(.NOT.C_ASSOCIATED(res_LPVOID)) then write(*,'(a,i0)') 'LockResource failed with error code ',GetLastError() stop end if block character(len=res_Size,kind=C_CHAR), pointer :: temp call C_F_POINTER(res_LPVOID, temp) fptr => temp end block filename = 'MyOutputFile.txt' open(newunit=iunit,file=filename,status='replace',access='stream') write(iunit) fptr end program txtres
The sequence to compile in gfortran is as follows:
gfortran -c ifwin.f90 windres -i txtresource.rc -o txtresource.o gfortran txtres.f90 ifwin.o txtresource.o -otxtres
Then after running txtres.exe, we get an output file MyOutputFile.txt:
Thanks a lot Repeat Offender for your contribution. I agree this could easily be modified so that it can be used with IVF.
Actually with the new release *today* that supports stdcall attribute with bind(c) you only need to replace the lines as below i think!
!gcc$ attributes stdcall with !DEC$ attributes stdcall
Oh, my! I wasn't aware that Intel had sdtcall + bind(C) in the works, but now, as you say, it's there in the release notes. Yumyumyum...
Support for the BLOCK construct in today's ifort makes porting easier too, no longer requiring us to change over to a subroutine to get to a scope where we can name the LEN of a character variable pointer.
But what I was anticipating was that ifort users of my example would not want to write their own partial ifwin.mod but rather use the intrinsic version that comes with the compiler. Certainly in that case we would have to modify the line
to
res_LPVOID = transfer(LockResource(res_HGLOBAL),res_LPVOID)
and maybe some other niggling things the compiler probably would warn us about, and of course invoking rc.exe works differently from windres.exe, but hopefully someone can make this work in ifort pretty quickly.
