Trouble Linking
scrognoid
I am evaluating the latest Intel Fortran Compiler in the VS 2005 IDE. I'm having trouble linking to several sources. I'll start with what I think might be the easiest.
I successfully built compat.lib. I can't link to routine. I tried Project>Properties>Linker>Input>Additional Dependencies. I put in the entire path.
Error 9 error LNK2001: unresolved external symbol _CM_MSLEEP sleep_and_check.obj
Apparently I should be able to specify a project dependency. I tried right-click Solution 'fft_auto'>Project Dependencies. There is a Depends On box, but I can't enter anything into it.
sarma_amras
Quoting - scrognoid
May I know how are you creating the projects.
Under the same solution or as separate solutions.
My suggestion is to create seperate solutions for C & Fortran project and then enter the Additional Dependencies correctly.
It should be simple.
Also make sure that the Naming of the function should be matching. i.e. either Caps or small in both C & Fortran.
Else you need to make the changes to the Calling naming convention under Fortran->External Procedures to lowercase if your C function is in lowercase.
Hope this will rectify the err.
sarma_amras
Quoting - scrognoid
Jugoslav_Dujic
Valued Contributor II
Quoting - sarma_amras
You meant "projects" rather than "solution", because a solution is a collection of projects.
scrognoid
Thanks for the help. I have worked through many issues, and separating C and Fortran into separate projects was part of it. The C routines I was trying to link never made it into the library.
