29649 Discussions
Truncation error-maximum memory limit
njayashree
Machine architecture- Intel dual-Nocona (EMT64) 3.2 GHz based with 4 GB RAM .
The complier used is l_fc_p_9.0.021 with RHEL-4 64bit OS.
The following error occurred while compiling a program that requires more than 2GB memory.
We are using static memory allocation.
/tmp/ifort6dAX75.o(.text+0x28d): In function `MAIN__':
: relocation truncated to fit: R_X86_64_32S mat_
/tmp/ifort6dAX75.o(.text+0x2cb): In function `MAIN__':
/tmp/ifort6dAX75.o(.text+0x2eb): In function `MAIN__':
/tmp/ifort6dAX75.o(.text+0x35d): In function `MAIN__':
: relocation truncated to fit: R_X86_64_PC32 mat_
/tmp/ifort6dAX75.o(.text+0x388): In function `MAIN__':
/tmp/ifort6dAX75.o(.text+0x3b3): In function `MAIN__':
/tmp/ifort6dAX75.o(.text+0x450): In function `MAIN__':
: relocation truncated to fit: R_X86_64_32S all_
/tmp/ifort6dAX75.o(.text+0x496): In function `MAIN__':
: relocation truncated to fit: R_X86_64_PC32 all_
/tmp/ifort6dAX75.o(.text+0x50d): In function `MAIN__':
/tmp/ifort6dAX75.o(.text+0x519): In function `MAIN__':
/tmp/ifort6dAX75.o(.text+0x5d3): In function `MAIN__':
: additional relocation overflows omitted from the output
TimP
Have you read earlier posts on this forum regarding x86-64 static memory limitations, and desirability of a more current compiler version?
njayashree
I have checked the earlier posts. They do not address for the latest version of the fortran compiler version in my previous posting.
njayashree
The following command allows unlimited memory for the executable of a single program.
ifort -i-dynamic -mcmodel=large -o filename
njayashree
I apologize for an error in the previous posting. The command is-
ifort -i-dynamic -mcmodel=large filename.f -o filename
The above allows unlimited memory for the executable of a single program in EMT64 based 4GB memory processor machine with intel fortran 90 compiler, version l_fc_p_9.0.021. Thanks
