29376 Discussions
Trying to rebuild application with .bat files
Jonas231
I am trying to recompile a legacy code "http://ecalculations.com/".
The recompile and the link are done with simple .BAT files.
How can I do this with Visual Studio and Intel One APi? Or should I use the Command Line environment?
Which commands to use?
There are various .bat-files:
MAKE.bat:
CD\WINOPT
DEL ODP.EXE
DEL PRG.EXE
CALL AM
link @automake.lnk
AM.bat
@Echo OFF
AUTOMAKE type=%1 %2 %3 %4 %5 %6 %7 %8 %9
@IF ERRORLEVEL 1 GOTO delete
call AMTEMP
:delete
DEL AMTEMP.BAT
MAKEKDP_IVF.bat
CALL IFORTVARS
CD\WINOPT_IVF
del kdp2.exe
call am
link @automake.lnk
DEL *.F90
ifortvars.bat
@Echo off
Rem Intel(R) Visual Fortran Compiler Build Environment for 32-bit applications
echo.
echo Intel(R) Visual Fortran Compiler 9.1.024 Build Environment for 32-bit applications
echo Copyright (C) 1985-2006 Intel Corporation. All rights reserved.
echo.
@call "C:\Program Files\Microsoft Visual Studio 8\VC\Bin\Vcvars32.bat"
title Intel(R) Visual Fortran Compiler 9.1.024 Build Environment for 32-bit applications
echo.
SET IFORT_COMPILER91=C:\Program Files\Intel\Compiler\Fortran\9.1
SET INTEL_SHARED=C:\Program Files\Common Files\Intel\Shared Files
SET INTEL_LICENSE_FILE=C:\Program Files\Common Files\Intel\Licenses
SET PATH=%IFORT_COMPILER91%\Ia32\Bin;%INTEL_SHARED%\Ia32\Bin;%PATH%
SET LIB=C:\Program Files\Intel\Compiler\Fortran\9.1\IA32\LIB;C:\Program Files\Microsoft Visual Studio 8\VC\lib;%IFORT_COMPILER91%\Ia32\Lib;%LIB%
SET INCLUDE=%IFORT_COMPILER91%\Ia32\Include;%INCLUDE%
if exist "C:\Program Files\Intel\Compiler\Fortran\9.1\ia32\Bin\imsl.bat" call "C:\Program Files\Intel\Compiler\Fortran\9.1\ia32\Bin\imsl.bat"
Does anyone have a clue what is done here? Where can I read about compiling and building
with .bat-files?
Kind regards,
Jonas
mecej4
OK, I now see that you have exposed a regression in not only the slightly earlier compiler version that you reported about but also the latest Ifort Version 2021.2.0 Build 20210228_000000 and Ifx Version 2021.2.0 Beta Build 20210317 compilers.
cean
New Contributor II
I installed 2021.1 first, then upgraded to 2021.2.
Under my d:/oneAPI/compiler, there are folders of 2021.1.1 and 2021.2.0
So have to wait for another upgrade now?
mecej4
If  Intel personnel do not read this thread and create a bug report in time for the forthcoming release, you may have to wait until the second next release.
cean
New Contributor II
cean
New Contributor II
Interesting project.
Is the 64bit version ever released?
