29653 Discussions
Trying to register software (Intel® Parallel Studio XE Professional Edition for Fortran Windows)
VicSchabort
Error given when trying Software Registration in User Portal:
An unexpected error occurred. Please refresh and try again, or contact the IRC team
Alessio436
Hey,
seems like a temporary issue on intel’s registration backend rather than something on your side. the “unexpected error” message appears when the user portal fails to reach the licensing service, which happens occasionally after account migrations or maintenance.
try clearing browser cache or using an incognito window first — if that doesn’t work, go directly to https://www.intel.com/content/www/us/en/forms/software-registration.html and try signing in again. if it still fails, email [email protected] (Intel Registration Center) with your serial number and the product name “Intel Parallel Studio XE Professional Edition for Fortran for Windows” — they can manually register or fix your license record.
Steve_Lionel
Why bother registering a now-ancient and unsupported version? Get the free Intel oneAPI Fortran Compiler - no registration necessary.
JohnNichols
Honored Contributor I
It is better and it runs 1972 code sweetly.
Alessio436
Hey,
VicSchabort
Thanks, I tried a few times already but not yet success.
Installed VS2022 , oneAP Base toolkit and oneAPI Intel Fortran essentials according to instructions.
However, after opening VS2022, no Fortran options are available.
Could you perhaps guide me to install instructions for one API Fortan under Visual Studio.
Steve_Lionel
I was going to point you to an Intel article on configuring Visual Studio for use with Intel compilers, but Intel deleted it (or changed its location)! The short answer is to do a "modify" on Visual Studio, select the "Desktop applications using C++" component, then redo the Intel Fortran install.
VicSchabort
Thanks a lot for that.
Please forgive, but I don't know what you mean by "modify" on Visual Studio, select the Desktop applications using C++ component....
Can you please clarify a bit more clearly what I should do to solve the issue.
I am not a regular user of Visual Studio - I use Rad Studio and C++ Builder
VicSchabort
Ok I think I know what you mean.  I am doing it right now. Will let you know if I have problems. Thanks
VicSchabort
I got it going.!!
Thanks for the help!
Steve_Lionel
You're welcome.
Steve_Lionel
FWIW, here is the archive.org copy of the deleted page. Intel likes to quietly delete pages that reference older product versions even if the info is is still applicable to current versions.
