Two new ICEs
OP1
New Contributor III
These ICEs were obtained with IVF 17 Update 4 on a 64-bit Windows machine.
For the first ICE, the issue disappears if line 15 is uncommented and line 18 is commented (that is, the opposite of the condition in which the ICE occurs):
MODULE M
    TYPE T
        CONTAINS
            PROCEDURE :: P => T_P
    END TYPE T
    INTERFACE
        MODULE FUNCTION T_P(S) RESULT(R)
            REAL :: R
            CLASS(T),INTENT(IN) :: S
        END FUNCTION T_P
    END INTERFACE
END MODULE M
MODULE N
    !USE M
    INTERFACE
        MODULE SUBROUTINE F(A)
            USE M
            TYPE(T),INTENT(IN),OPTIONAL :: A
        END SUBROUTINE F
    END INTERFACE
END MODULE N
For the second ICE, the issue disappears if lines 7 & 8 are uncommented, and lines 9 & 10 are commented (that is, the opposite of the condition in which the ICE occurs):
MODULE M
    TYPE T
        CONTAINS
    END TYPE T
    INTERFACE
        !MODULE FUNCTION T_P(S)
        !    REAL :: T_P
            REAL :: R
        END FUNCTION T_P
    END INTERFACE
END MODULE M
MODULE N
    INTERFACE
            USE M
        END SUBROUTINE F
    END INTERFACE
END MODULE N
I would like to know if these errors are still present in higher versions (either 17, 18 or 19). This will help me justify upgrading our current compilers.
Thanks!
IanH
The two example stretches of code have identical semantics.
I still see the problem with ifort 19.0.  Have you reported it?
OP1
New Contributor III
Thanks for confirming that this issue is still there with 19.0.
