29648 Discussions
Type Bound Generic Assignment Bug Using Intrinsic Assignments
schiffmann__florian
Hello everybody,
I assume I ran into a bug with Intel Fortran 19.0.5.281. I ran into this problem writing a reference counting scheme.
The problem can be tested with this program:
MODULE Classes
    IMPLICIT NONE
    TYPE Inner_
       INTEGER                       :: iCount=0
    END TYPE
    TYPE Inner
       CLASS(Inner_), POINTER         :: this => NULL()
       CONTAINS
       PROCEDURE                     :: init
       PROCEDURE                     :: assignMe
       GENERIC                       :: assignment(=) => assignMe
       FINAL                         :: deleteIt
    END TYPE
    TYPE user
       TYPE(Inner)    :: mInner
    END TYPE
CONTAINS
   SUBROUTINE init(self)
      CLASS(Inner), INTENT(OUT)      ::  self
      ALLOCATE(Inner_ :: self%this)
      self%this%icount=1
   END SUBROUTINE
   SUBROUTINE deleteIt(self)
      TYPE(Inner)          ::  self
      IF(ASSOCIATED(self%this)) THEN
         self%this%icount=self%this%icount-1
         IF(self%this%icount==0)DEALLOCATE(self%this)
      ENd IF
   END SUBROUTINE
   ELEMENTAL IMPURE SUBROUTINE assignMe(self, input)
      CLASS(Inner), INTENT(IN)      ::  input
      IF(ASSOCIATED(input%this))THEN
         self%this=>input%this
         self%this%icount=self%this%icount+1
      END IF
   END SUBROUTINE
END MODULE
PROGRAM test
   USE Classes
   IMPLICIT NONE
WRITE(*,*)"Assign Each Element(Works as expected)"
   BLOCK
      TYPE(user)          :: mOuter(2), reassigned(2)
      CALL mOuter(1)%mInner%init()
      CALL mOuter(2)%mInner%init()
      reassigned(1)=mOuter(1)
      reassigned(2)=mOuter(2)
      WRITE(*,*)"mOuter(1)    ", mOuter(1)%mInner%this%iCount , "EXPECTING 2"
      WRITE(*,*)"mOuter(2)    ", mOuter(2)%mInner%this%iCount , "EXPECTING 2"
      WRITE(*,*)"reassigned(1)", reassigned(1)%mInner%this%iCount , "EXPECTING 2"
      WRITE(*,*)"reassigned(2)", reassigned(2)%mInner%this%iCount , "EXPECTING 2"
   END BLOCK
WRITE(*,*)
WRITE(*,*)"Assign intrinsic vector(Does not increment reference count)"
   BLOCK
      reassigned=mOuter
   END BLOCK
END PROGRAM
The produced output is:
 mOuter(1)               2 EXPECTING 2
 mOuter(2)               2 EXPECTING 2
 reassigned(1)           2 EXPECTING 2
 reassigned(2)           2 EXPECTING 2
 mOuter(1)               1 EXPECTING 2
 mOuter(2)               1 EXPECTING 2
 reassigned(1)           1 EXPECTING 2
 reassigned(2)           1 EXPECTING 2
As it can be seen, using an element by element assignment increases the counter by calling the type bound assignment.
However using a vector assignment for the outer class does not call the type bound assignment function.
I would expect the vector assignment to be a shorthand notation for the element by element assignment. Is this correct?
Best regards
Flo
Steve_Lionel
Yes. See paragraph 2 of Fortran 2018 section 10.2.1.4 (Defined Assignment).
A subroutine defines the defined assignment x1 = x2 if
... (5) either
(a) the ranks of x1 and x2 match those of d1 and d2 or
(b) the subroutine is elemental, x2 is scalar or has the same rank as x1, and there is no other
 subroutine that defines the assignment.
