29286 Discussions
Type KIND of PARAMETER lost when used as TRANSFER MOLD
Espen_M_
The following two statements does *not* produce the same result:
[fortran]
PRINT *, KIND( TRANSFER(real_num,equal_size_int) )
PRINT *, KIND( equal_size_int )
[/fortran]
where equal_size_int is a PARAMETER accessed through a MODULE.
This must be an error...
Did you perhaps mean to write:
TRANSFER(real_num,0_equal_size_int)
? What you have is just an integer whose value is equal_size_int with default kind.
Espen_M_
equal_size_int is the name of the integer parameter, it can have any value and is not intended as a kind parameter (which would have to have the values 1, 2, 4 or 8 in IFORT)
But regardless of that, shouldn't the two statements produce the same result?
Please show me a complete source that demonstrates the problem. I can't see it from those two lines.
