Type Observation
JohnNichols
Honored Contributor I
Steve:
I ran into some interesting Fortran behaviour yesterday.
I declared L as a real and it used it to describe length.
Then later I added a write statement that had (x(L),L=1,N) - I was not thinking
it compiled and did not complain about the second L -- but actually counted weirdly -- I got twice the number of elements from X printed out, each second one was zero.
Took me a while to track down the error.
John
Steve_Lionel
John,
First, I find it puzzling that you keep addressing questions to me directly. This is a community forum and many people may have the answer to your question. On top of that, I have no special status here other than as an experienced user, albeit one with some insider knowledge. By addressing me specifically, you may be inhibiting others from responding.
Second, your use is non-standard but the compiler will allow it, unless you enable standards checking. For example:
t.f90(7): warning #6187: Fortran 2008 requires an INTEGER data type in this context.
print *, (X(L),L=1,10)
In the example I tried, it worked as I would expect. Please show a small test case that behaves in the manner you describe.
REAL DO-loop control variables used to be allowed in the standard, but were deleted from the standard as of Fortran 95. DEC/Compaq/Intel Fortran continues to allow it as a non-standard usage.
JohnNichols
 subroutine RKNB(N, h, m, t0, dt, L, vt, H20, NT, Freq,NR, X,DX, XStart, ModelA)
    use Base
    use Bridge
    implicit none
    TYPE (Model), TARGET :: ModelA
    TYPE (EquationA), TARGET :: Equation1
    integer N
    integer I
    Integer m
    INTEGER NT
    Integer NR
    Integer K
    Integer J
    integer km, km1
    REAL (KIND=dp) h
    REAL (KIND=dp) X(N)
    REAL (KIND=dp) DX(N)
    REAL (KIND=dp) z(2)
    REAL (KIND=dp) tau
    REAL (KIND=dp) xstart,xf(N),xdf(N), xdd(N)
    REAL (KIND=dp) t0
    REAL (KIND=dp) dt, dtmin
    REAL (KIND=dp) time
    REAL (KIND=dp) L
    REAL (KIND=dp) vt                   !   Velocity of the truck
    REAL (KIND=dp) LAxle1
    REAL (KIND=dp) LAxle2
    REAL (KIND=dp) H20(NT)
    REAL (KIND=dp) eps(mn1), BGH, eqM, eqB
    REAL (KIND=dp) Ri(m,mn1)
    REAL(KIND=dp)Freq(NR,mn1), max,min
    Real(kind=dp) Defl(m)
    Real(kind=dp) Velc(m)
    Real(kind=dp) maxB(100)
    Real(kind=dp) VBNN(100)
    logical Axle1On
    logical Axle2On
    ! Start points
    z(1) = 0.0_DP
    z(2) = 0.0_DP
    tau = ZERO
    ModelA%LastY = ZERO
    max = -10000.0
    min = 10000.0
    Write(*,100)N,h
    Write(sRB,100)N,h
100 Format(/,'----------------------------------------------------------------------------------------------------',//,&
        '             Runge Kutta Nystrom Solution for Bridges!',//,&
        '             Number of equations                              :: ',I4,/,&
        '             Tolerance (m)                                    :: ',F10.5)
    if(N .ne. EIGHT) then
        stop 'There are eight equations refer to Fryba(1999) Vibrations of Solids and Structures undermoving loads'
    else
        write(*,390)
        write(sRB,390)
390     Format(/'             There are eight equations refer to ::',/,'             Fryba, L., (1999) Vibrations of Solids and Structures undermoving loads, Telford: London UK',/)
    endif
    do 200 i=1,N
        if(i .eq. 1) then
            Write(*,300)
            Write(sRB,300)
300         Format('             Equation 1 :: Fryba Equation 38 ')
            call FirstEquation(ModelA, Equation1)
        else if(i .eq. 2) then
            Write(*,310)
            Write(SRB,310)
310         Format('             Equation 2 :: Fryba Equation 39 ')
        else if(i .eq. 3) then
            Write(*,320)
            Write(sRB,320)
320         Format('             Equation 3 :: Fryba Equation 37 ')
        else if(i .eq. 4) then
            Write(*,330)
            Write(sRB,330)
330         Format('             Equation 4 :: Fryba Equation 36 ')
        else if(i .eq. 5) then
            Write(*,340)
            Write(sRB,340)
340         Format('             Equation 5 :: Fryba Equation 46 ')
        else if(i .eq. 6) then
            Write(*,350)
            Write(sRB,350)
350         Format('             Equation 6 :: Fryba Equation 46')
        else if(i .eq. 7) then
            Write(*,360)
            Write(sRB,360)
360         Format('             Equation 7 :: Fryba Equation 52')
        else if(i .eq. 8) then
            Write(*,370)
            Write(sRB,370)
370         Format('             Equation 8 :: Fryba Equation 52',//)
        endif
200 end do
    write(*,1101)ModelA%chi,ModelA%chiZero,ModelA%freq1,ModelA%Freq(1,1),ModelA%gamma1,ModelA%freq2,ModelA%gamma2,ModelA%gamma22,Equation1%neta(1),Equation1%neta(2)
    write(srB,1101)ModelA%chi,ModelA%chiZero,ModelA%freq1,ModelA%Freq(1,1),ModelA%gamma1,ModelA%freq2,ModelA%gamma2,ModelA%gamma22,Equation1%neta(1),Equation1%neta(2)
1101 Format('             Chi Factor Load Ratios :: ',F7.3,/,&
        '             Chi Zero Factor        :: ',F7.3,/,&
        '             Frequency 1            :: ',F7.3,/,&
        '             Frequency 1,1          :: ',F7.3,/,&
        '             Gamma 1                :: ',F7.3,/,&
        '             Frequency 2            :: ',F7.3,/,&
        '             Gamma 2                :: ',F7.3,/,&
        '             Gamma 22               :: ',F7.3,/,&
        '             Damping Ratio 1        :: ',F7.3,/,&
        '             Damping Ratio 2        :: ',F7.3,/)
    if(N .eq. 8) then
        ! write(*,500)
        write(srB,500)
500     format(//'----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------',/&
            '                                                 General Second Order Equation - Solution for a Bridge Problem.        ',//,&
            '            Meaning of the terms ::',//,&
            '                                    Count     ::  The analysis step in integer count.',/,&
            '                                    Time      ::  The time of the analysis point in seconds. At 25 m/s it takes 1.2 seconds to traverse a 30 metre bridge.',/,&
            '                                    Tau       ::  Dimensionless time - 1 unit equals time for front wheels to traverse the bridge.',/,&
            '|Count     Time        TAU      |                                               Displacement/Rotation                             |                                Velocity/ Angular Velocity                                       |                               Acceleration / Angular Acceleration                               | Deflection |',/,&
            '|                               |       1            2          3           4           5           6           7          8      |       1            2          3           4           5           6           7          8      |       1            2          3           4           5           6           7          8      |   Total    |',/)
    elseif(N .eq. 2) then
        write(*,510)
510     format('  Count  Time     XF      XF     XDF     XDF')
    endif
    time = t0
    LAxle1 = t0
    LAxle2 = LAxle1 - H20(1)
    write(sRA,418)
    write(*,418)
418 Format("Count",",","Time",",","Tau",",","X5",",","X6",",","X7",",","X8",",","DX5",",","DX6",",","DX7",",","DX8",",","DDX5",",","DDX6",",","DDX7",",","DDX8",",","DY*VBN",",","RBig1",",","RBig2")
    do 600 i=1,m
        Ri(i,1) = ZERO
        Axle1On = .false.
        Axle2On = .false.
        if(LAxle1 .gt. ZERO .AND. LAxle1 .lt. L )then
            AXLE1On = .true.
            Ri(i,1) = ((ONE/FortyEight)*(pi**FOUR))*(H20(2)/gr)*((Freq(1,1)/Freq(1,1))**TWO)
        endif
        if(LAxle2 .gt. ZERO .AND. LAxle2 .lt. L )then
            AXLE2On = .true.
        endif
        if(LAxle1 .gt. L)then
            !AXLE1On = .false.
            Ri(i,1) = ZERO
        endif
        if(LAxle2 .gt. L)then
            ! AXLE2On = .false.
        endif
        if( Laxle1/L .le. ONE) then
            eps(1) = Laxle1/L
        else
            eps(1) = ZERO
        endif
        if( Laxle2/L .ge. ZERO .AND. Laxle2/L .le. ONE ) then
            eps(2) = Laxle2/L
        else
            eps(2) = ZERO
        endif
        ModelA%etaA = tau           ! set up for equaiton 9.49
        dtmin = dt
        !dt = dt / 100.0
        call nystrom_lear_44B(N,i,bridgeF,tau,X,DX,dt,xf,xdf, Equation1, ModelA, xdd)
        write(*,2091)i, N,(xdd(km),km=1,N)
2091    Format(i7, 2x, i4, 8(1x,F8.4))
        if(N .eq. 1) then
            write(*,400)I,t0,(xf(k),k=1,N),(xdf(km),km=1,N)
            write(srB,400)I,t0,(xf(k),k=1,N),(xdf(km),km=1,N)
            write(srA,401)I,t0,(xf(k),k=1,N),(xdf(km),km=1,N)
        elseif(N .eq. 8) then
            !write(*,420)I,time,tau,xf(5),xf(6),xf(7),xf(8),(ModelA%ydefl(i)*VBN)
420         Format(I5, 2x, 2(2x,F8.3),5(2x,F20.9))
            write(srB,416)I,time,tau,(xf(k),k=1,N),(xdf(km),km=1,N),(xdd(km1),km1=1,N),(ModelA%ydefl(i)*sqrt(VBN))
           ! write(*,4170)I,time,tau,(xf(k),k=1,N),(xdf(L),L=1,N),(xdd(L),L=1,N),(ModelA%ydefl(i)*VBN)
4170         Format(i4,F4.0,F4.0,25F9.2)
416         Format('|',I7,1x,2(1x,F11.8),' |',8(1x,F11.8),' |',8(1x,F11.2),(' |',F11.3),7(1x,F11.2),' |',1x,F11.2'|')
            write(srA,411)I,time,tau,xf(5),xf(6),xf(7),xf(8),xdf(5),xdf(6),xdf(7),xdf(8),xdd(5),xdd(6),xdd(7),xdd(8),(ModelA%ydefl(i)*sqrt(VBN)),ModelA%RBig(i,1),ModelA%RBig(i,2)
            if(max .lt. ModelA%ydefl(i)*sqrt(VBN)) then
                max = ModelA%ydefl(i)*sqrt(VBN)
            endif
Line 196 I originally had km set as L - but L was declared as real, it is in the file Lear.f90. With km it works with L it prints out twice as many results - half 0.0000
I do not have a small program - this is a general second order ODE solver - from the Lear paper from NASA.  I am in the process of putting in tolerance checking -- hence the printouts.
Main menu select 2 and the file name is CEDR
jimdempseyatthecove
Odd, it is ASIF it (using a double precision index) converted xdf and xdd to complex.
It may be that the older compilers treated the io-implied-do variables local in scope to the I/O statement (thus had integer type), the newer compilers export the last value from the scope of the I/O statement to that of the procedure. This behavior is a curious bug IMHO.
Must have been quite confusing to ascertain the problem.
Jim Dempsey
andrew_4619
...... but not at all confusing if you use standards checking.....the run time error would never have happened.
Steve_Lionel
I took your ZIP and built it in 19.1. I ran it first as-is to see what the expected output was, then rebuilt it substituting L as the implied-DO variable. I got identical results. I have to guess that you made some other change at the same time that affected the behavior.
Jim's theory is an interesting guess, but I am 100% confident that was never the behavior. It's interesting to note that in an I/O implied-DO, the DO variable is the host scope variable and not a statement-scope variable of the same name and type as that in the host, which is the case for array constructors.
JohnNichols
Thanks for the comment and the time spent,  two of the critical standards checkers were turned on.
Yes it was confusing I had zeros between a set of reals.
But now it has gone away.
Of course the real error not declaring a separate variable for the print statement.
