Unable to Compile
sang186
I have a fortran project to be compiled using the Visual fortran compiler. Although Visual Studio 2008 has been installed in the system along with the Intel Visual fortran compiler Professional Edition 11.1 for windows, I am not able to use it.
On going through the documentation, I found the following,
To start the compiler , Use the Start > All Programs list to locate and launch Microsoft Visual Studio.
After launching Visual Studio, do the following to use the Intel Visual Fortran Compiler:
1.Select File > New > Project.
2.In the New Project window select a project type under Intel Visual Fortran.
3.Select the desired template.
4.Click OK.
But when I did the same, I could not find a project type named Intel Visual Fortran. What should i do ?
Does this mean, I need to reinstall to associate the Visual Studio IDE to the Intel Visual Fortran ?
Kindly help me with this.
- Sangeetha.
Please follow the steps in this article to see if that resolves the problem. Let us know how it goes.
sang186
I am listing the observations from each step below.
Citing from the article
Step 1 :Are prerequisites met ? Point 3 says "Look under Installed Products to see if "Intel Visual Fortran Compiler Integration" is listed and make a note of the version number or "Package ID" displayed, if any. "
Observation 1 : It is not displayed under the installed products .
Step 2: are the integration files present?
Observation 2 : All dll's are present in the folder, 'C:\Program Files\Microsoft Visual Studio 8\Intel Fortran\VFPackages' but its version no is given as 11.1.3468.2005 (indicating visual studio 2005. Does this matter ? Or should it be 2008. I am using Microsoft visual studio 2008 Professional Edition)
With this should I run the repair too ? At present, I do not have Administrator priviledges to run the repair tool. I could get it if required.
The folder you looked in is the VS2005 folder. If you are using VS2008, look under Microsoft Visual Studio 9.0. You will need Admin privileges to run the repair tool on Vista or Windows 7.
In VS2008, please click Help > About. Click "Copy Info" and paste the results into a reply here.
sang186
"Copy Info" gave this :
Microsoft Visual Studio 2008
Version 9.0.21022.8 RTM
Microsoft .NET Framework
Version 3.5 SP1
Installed Edition: Professional
Microsoft Visual Basic 2008 91605-270-1097083-60583
Microsoft Visual C# 2008 91605-270-1097083-60583
Microsoft Visual C++ 2008 91605-270-1097083-60583
Microsoft Visual Studio 2008 Tools for Office 91605-270-1097083-60583
Microsoft Visual Web Developer 2008 91605-270-1097083-60583
Crystal Reports AAJ60-G0MSA4K-68000CF
Crystal Reports Basic for Visual Studio 2008
Hotfix for Microsoft Visual Studio 2008 Professional Edition - ENU (KB944899) KB944899
This hotfix is for Microsoft Visual Studio 2008 Professional Edition - ENU.
If you later install a more recent service pack, this hotfix will be uninstalled automatically.
For more information, visit http://support.microsoft.com/kb/944899.
Hotfix for Microsoft Visual Studio 2008 Professional Edition - ENU (KB945282) KB945282
For more information, visit http://support.microsoft.com/kb/945282.
Hotfix for Microsoft Visual Studio 2008 Professional Edition - ENU (KB946040) KB946040
For more information, visit http://support.microsoft.com/kb/946040.
Hotfix for Microsoft Visual Studio 2008 Professional Edition - ENU (KB946308) KB946308
For more information, visit http://support.microsoft.com/kb/946308.
Hotfix for Microsoft Visual Studio 2008 Professional Edition - ENU (KB946344) KB946344
For more information, visit http://support.microsoft.com/kb/946344.
Hotfix for Microsoft Visual Studio 2008 Professional Edition - ENU (KB946581) KB946581
For more information, visit http://support.microsoft.com/kb/946581.
Hotfix for Microsoft Visual Studio 2008 Professional Edition - ENU (KB947171) KB947171
For more information, visit http://support.microsoft.com/kb/947171.
Hotfix for Microsoft Visual Studio 2008 Professional Edition - ENU (KB947173) KB947173
For more information, visit http://support.microsoft.com/kb/947173.
Hotfix for Microsoft Visual Studio 2008 Professional Edition - ENU (KB947180) KB947180
For more information, visit http://support.microsoft.com/kb/947180.
Hotfix for Microsoft Visual Studio 2008 Professional Edition - ENU (KB947540) KB947540
For more information, visit http://support.microsoft.com/kb/947540.
Hotfix for Microsoft Visual Studio 2008 Professional Edition - ENU (KB947789) KB947789
For more information, visit http://support.microsoft.com/kb/947789.
Hotfix for Microsoft Visual Studio 2008 Professional Edition - ENU (KB948127) KB948127
For more information, visit http://support.microsoft.com/kb/948127.
Hotfix for Microsoft Visual Studio 2008 Professional Edition - ENU (KB953256) KB953256
For more information, visit http://support.microsoft.com/kb/953256.
Hotfix for Microsoft Visual Studio 2008 Professional Edition - ENU (KB971091) KB971091
For more information, visit http://support.microsoft.com/kb/971091.
Hotfix for Microsoft Visual Studio 2008 Professional Edition - ENU (KB973674) KB973674
For more information, visit http://support.microsoft.com/kb/973674.
Update for Microsoft Visual Studio 2008 Professional Edition - ENU (KB972221) KB972221
This update is for Microsoft Visual Studio 2008 Professional Edition - ENU.
If you later install a more recent service pack, this update will be uninstalled automatically.
For more information, visit http://support.microsoft.com/kb/972221.
I could not find the Intel Fortran folder in path 'C:\Program Files\Microsoft Visual Studio 9.0'
Please uninstall Intel Fortran and then reinstall it. You need to have administrator permissions to do an install.
sang186
Thank you for all the information, Steve. I'll do so and get back to you.
- Sangeetha
sang186
I uninstalled the software and reinstalled it. It is working perfectly.
The Intel Fortran was integrated with the previous version of the Visual Studio (VS2005), which on upgradation to the new version did not recognisethe compiler.
Thank you Steve.
- Sangeetha
