29641 Discussions
Undefined address when specifying double precision real variables
Richard_Moser
I have a code which was working fine. In trying to compare to some experimental results, I changed all of my real variables to double precision, at which point I got an access violation message, where an integer array is said to have an undefined address (the whole array, not just elements within it). If I go back to single precision real, it works fine.
In trying to narrow the problem down, I inserted a statement at the very top of the main code which tries to initialise the integer array, but I get the same problem.
Why does changing from single to double precision real affect the access of an integer array?
I am using compiler version 11.0.075, in Visual Studio 2005.
jimdempseyatthecove
Does your code contain COMMON with EQUIVALENCE?
The size change in real may move the former positions of equivalence.
Also, your calling arguments may now be messed up. Try geninterfaces and check interfaces (and use IMPLICIT NONE if possible)
Jim Dempsey
Richard_Moser
Jim,
Thanks for your response. I am using IMPLICIT NONE, and I do not have any COMMON statements.
The error occurs before any calls are made.
Richard
Les_Neilson
Valued Contributor II
Quoting - Richard Moser
Jim,
Richard
Do you have any EQUIVALENCE statements ?
As jim mentioned turn on interface checking (Project->Properties->Fortran->Diagnostics)
If that doesn't show up any compile messages then :
The usual suspects :
turn on all debugging flags : (Project -> Properties -> Fortran -> Run-time -> Runtime Error checking : ALL
Put a "breakpoint" on the first statement of your program
Run your program (in debug mode of course)
It should stop on thatfirst breakpoint
Pressing F10 will then step though the program one statement at a time until you get to the error. This should give you a better idea of where the problem lies.
Les
Richard_Moser
Quoting - Les Neilson
Les
Les,
I don't have any EQUIVALENCE statements in the code. Interface checking was already active, with no messages during compilation, and runtime error checking was set to ALL.
I had already moved the troubled statement to the very start of the main program, to ensure that no other routines were interfering.
I declare my integer array as INTEGER N_ORDS(6)
My first executable statement in the code is then:
DO I = 1, 6
N_ORDS(I) = 0
ENDDO
and it fails on execution, listing the elements of N_ORDS as having an undefined address. There are also other (single value) integer variables which are listed as this. All REAL variables seem to be ok (uninitialised, but having an address).
Richard
jimdempseyatthecove
Richard,
Can you submit a simple example program that exhibits this behavior?
Note,
If you are debugging the Release build with optimizations, and if N_ORDS is not used, or used only within that routine (but not modified after initialization) then the compiler might optimize out the N_ORDS array.
Jim Dempsey
