29637 Discussions
Undefined reference to _for_realloc_lhs
Lendormy__Simon
Good Morning,
I am currently trying to compile a SDK that was handed to me, however, i am running into an issue i can't resolve.
The SDK's documentation requires the installation of Intel Fortran  Redistributable Library, parallel studioXE 2017.
When i am launching the the build, i get multiple errors "Unresolved external symbol _for_realloc_lhs".
i have seen on this forum someone who had the same problem and he was told this came from the use of a fortran compiler that was too recent, However, the SDK i am trying to build features pre-built fortran libraries, which i do not own the sources.
I would like to know if there is anything i am missing here, or if the libraries i was handled were compiled with the wrong tools.
If yes, would there be a way to download old enough fortran libraries in order to be able to work with this SDK.
Tank you in advance
Steve_Lionel
You also asked this on Stack Overflow, and I see from your edited post there (thank you) that you're on Windows. This is the Linux/Mac forum, the Windows forum is here.
From the additional information you gave there, it seems that you are using a very old redistributable (from version 11.1) and you need to get the current one (for Windows, not Linux.)
Lendormy__Simon
I am so sorry for the mistake i made posting on this forum. I also made another post because this one took a very long time to appear on the forum and i though i did not send it properly, please ignore it.
Finally, i can tell the problem i am having is related to the installer, i will post on the windows forum & stack overflow.
Your answers are very helpful, thanks!
