I'm compiling a win32 console application with massive numerical computations.
When a use the compiled apllication in a machine with an AMD processor I got strange results.
I already try to change the my project flags for arch and also floating point model, but the result is allways the same.
Is there any other configuration that I should use to get the correct result?
Damiani
Can you provide us a sample program that shows this problem? The default options should work. What specific model of AMD processor does your system have?
