29386 Discussions
Unformatted file I/O difference between Debug and Release
NotThatItMatters
I have code which has the option of dumping memory to a file and then later reading this file to repopulate memory for a later run.  I am noting that I can run the code in Release mode without error, and yet in Debug mode the READ statements crash with the claim, input beyond end of record.
The READ statements contain within the program two REWIND statements for the file.  I have put some tracking statements to a file to see where the problem lies, but there is no apparent reading out of sequence.
You've got other /fpscomp options set in Debug and not release. These need to match. For example, you have /fpscomp:ioformat set in the Compatibility property page in Debug but not in release. General was set on the Compatibility page in Debug but as "Additional Options" in release. Make all these match.
There is likely an error in your code, perhaps an uninitialized variable. Without a test case there's no way to tell. File I/O is not handled any differently in debug or release modes, so the difference is almost certainly variable related.
Thanks for sending the project file. You had /fpscomp:general set in the Debug configuration but not in Release, and this very definitely changes the structure of unformatted files.
NotThatItMatters
If memory serves, the switch /fpscomp:general was set in the Debug configuration so that the output of my direct access files would be equivalent when running Debug or Release.  Without this switch, the fixed record length file created with the Debug configuration had LF as an end-of-line indicator whereas the Release had CR/LF.
The bonking line at present is something along the lines of
WRITE(IOCODE) (ARRAY(I), I = 1, IJD)
or
READ(IOCODE) (ARRAY(I), I = 1, IJD)
where IJD is 0.
NotThatItMatters
Steve,
Thank you for the help.  The options have pointed out some old unique ways the file dumps were being synchronized, including the reading of formatted direct-access files as sequential files.  This has improved several items, if only for code standardization.
Thank you again.
