29605 Discussions
Unhandled exception in __intel_alloc_bpv@4()
jim_cox
This ought to be simple but...
__intel_alloc_bpv@4() is giving me an unhandled exception
The code looks like...
PROGRAM MAIN
CALL ASSPAM(ERRCHK)
CALL ASSPAM(ERRCHK)
The first subroutine works fine
But the second generates an exception as it begins.
The two routines are broadly similar and are not complicated
Compiler version is 11.1.038
Any ideas what might be generating this error?
advTHANKXAnce
Jim
=mjc=
intel_alloc_bpv is called when you pass a procedure that requires uplevel context. It is also used when a program uses Variable Format Expressions. See my Doctor Fortran post Think, Thank, Thunk for some observations on this. It could be that the stack is getting corrupted across the first call.
What is ERRCHK?
jim_cox
What is ERRCHK?
LOGICAL*4 ERRCHK
Used to check that the routines are happy
.FALSE. on entry
What are 'Variable Format Expressions'?
Variable Format Expressions are expressions in a format enclosed in angle brackets, like this:
100 FORMAT (F5.2)
Does this program have a CONTAINS statement? Can you attach the actual code?
jim_cox
100 FORMAT (F5.2)
There is no CONTAINS
Files attached - mail routine is ASSIGN.F
Crashes on the call to ASSLOD at line 245
Have found that if I replace the crashing call with a repeat call to ASSPAM (which worked ok first time at line 124 ) the same error occurs.
I really am stuck on this one - your help is appreciated
Thankx
Jim
PS: apologies for the coding style - the code base this comes from is over 25 years old - and it shows :(
Les_Neilson
Valued Contributor II
Unfortunately you didn't add all of the include files so I can't test your program; but compiling assign.f I find that IZONE is used to declare the size of various arrays (eg in the common blocks in assign.i) but IZONE is not given a valueanywhere in the code you attached! (Presumably it is in one of the include files not attached)
There are other variables without a type (eg LONGFILENAMES used as a logical)
Another thought :since this is old codeyou may need to see if itis relying on the original compiler giving variables an initialdefault value.
Les
jim_cox
Quoting - Les Neilson
Les
I've attached a zip file which has, I hope, everything needed to compile the code. It is a huge codebase, so I may have well have missed something
There is also a couple of datafiles that are needed if you get it to run. I would also suggest you comment out the CALL ASSNET(ERRCHK) at line 154 to avoid trying to open a full dataset. The errior is still present if you do.
But specifically IZONE is declared
INTEGER, PARAMETER :: IZONE=999
in
INCLUDE 'D:SUITEINCLUDESLPARM.I'
called from
INCLUDE 'ASSIGN.I'
I have the compiler warning for undeclared variables on - Assign.f only warns for GDLY (which is a function in gdly.f)
Your comment about uninitialised variables is pertinent, but in my experience most of this code doesnt do that - rather they are created automatically by refering to them, or by assigning them a value
Thankx for your help
Jim
=mjc=
Les_Neilson
Mmm
Well I downloaded it and created a new project (made some code changes to remove the d: stuff from the includes).
You are right when you say the code is a mess :-) for one thing it contains tab characters which plays havoc with the positioning of the '+' continuation character in fixed format code.
When I compile qlong95.f for example I get lots of errors not least of which there is an "END" statement part way through the code (near line 995) Thereare twoinclude MOVE.I statements, the compiler thinks one of them is within executable code because it comes after an assignment NTH = 0.50 but then there are repetitions ofREALRHO etc, REAL L and REAL T
The firstfive non-system calls in the main program assign.f are
call GAPINI, TRXOPN, PARAM, VERCHK, CLRPAG
none of which are included in the zip file. Though my guess is that CLRPAG and CURSOR (called in ASSPAM for example) are calls to clear the screen and position the cursor?
Just had another thought. Doesthe coderely on local variables (non common)being automatically SAVEd or re-initialisedon subsequentcalls? For example default initialisation implies save.
Les
jim_cox
Mmm
Les
Yes the tab characters do cause a right pain....
QLONG95.F is not actually being used - has been replaced by QLONG.F
which has 95 compiler
'warning #6717: This name has not been given an explicit type'
messages - but no errors
You will find GAPINI etc in TrxCnFnD.LIB - can supply code and project files if needed. The D in the name is for debug. There is also a release versuon TrxCnFn.LIB
Re the SAVE option - the original code compiles and runs ok with MS Fortran Powerstation v 4.0. I dont think it has a save option for local vars - and I dont think the code expects it.
Any other thoughts?
Jim
