29642 Discussions
Uninitialized variable with correct value
Don_D_
My code sets a variable IC2:
    IC2 = IFLAGS(17,JCONF)
A few lines later it uses this value, which equals the number 2:
    JCOL = IC2
Then, later I use it again:
    DO K = 1,JTRAN        ! RETRACE ENTIRE RAYSET, THIS TIME TO GET GLASS ABSORPTION
        XEN = XR(K)        ! USE ONLY RAYS THAT GOT THROUGH LAST TIME
        YEN = YR(K)
        AT = AT + AR(K)        ! APODIZATION ONLY
        IF (JPOLD(JCONF) .EQ. 1) THEN    ! POLARIZATION OFF; NO LOSS FROM THAT
            XYAR(K) = 1.0
        ENDIF
        BT = BT + XYAR(K)        ! COATINGS ONLY
        ISTOP = MX
        ICOL = IC2
Only this time I get an error saying that IC2 is not defined!  In the debugger it still has the value it had when defined earlier.  What's going on?
Don_D_
My bad.  I had a dimension mismatch.  Fixed it.
Don_D_
jimdempseyatthecove
Does the error occur in an OpenMP region with default(none)?
Or, is the variable IC2 or lC2?
Note, left variable has upper case i and the right variable is lower case L
Jim Dempsey
andrew_4619
I may add that I always use the option "Local Variables AUTOMATIC (/Qauto) " which means  the locals become undefined when you exit the subroutine rather than saving the last value used  which often masks many "uninitialised" variable errors.  With a old program you will find this option throws up quite a number of errors but in reality  these are all bugs that should be fixed.
