Unknown VS2010 error during load
nvaneck
I recently started gettingan exception when I start VS2010
and it said to run with /log. In the log is this error, relating to the edotor or editor extension:
System.NullReferenceException: Object reference not set to an instance of an object. at Intel.Fortran.IFLangService.DropDownBar.CalculateNestedSelection(Int32 line) at Intel.Fortran.IFLangService.DropDownBar.CaretPositionChanged(Object sender, CaretPositionChangedEventArgs e) at Microsoft.VisualStudio.Text.Utilities.GuardedOperations.RaiseEvent[TArgs](Object sender, EventHandler`1 eventHandlers, TArgs args) Editor or Editor Extension 2011/11/22 02:24:37.410
225 ProductID:
It also containd this warning relating to VS:
The CTM file is out of date and should be deleted and rebuilt, but the file 'C:\\ProgramData\\Microsoft\\VisualStudio\\10.0\\1033\\devenv.CTM' could not be deleted.
How can I fix these? Are they harmless?
Thanks!
nvaneck
Well, never mind; it disappeared as mysteriously as it appeared.....
