29419 Discussions
Unlimited polymorphic arguments and Overriding type-bound procedures
John4
Valued Contributor I
I'm still trying to understand how an unlimited polymorphic argument works (and the Fortran standard is not very helpful), so I'm not really sure if the following code is valid:
[fortran]module mod1
    implicit none
    save
    type, abstract, public :: t_base
        integer :: dummy = 0
    contains
        procedure :: do_something
        procedure :: do_something_else
    end type
contains
    subroutine do_something(this, item)
        class(t_base), intent(IN) :: this
        class(*), pointer, intent(INOUT) :: item
    end subroutine
    subroutine do_something_else(this, item)
        class(*), pointer, intent(INOUT) :: item(:)
    end subroutine
end module mod1
module mod2
    use mod1
    implicit none
    save
    type, extends(t_base), public :: t1
        integer :: mydummy
    contains
        procedure :: do_something => do_something_local
    end type
    type, extends(t_base), public :: t2
        integer :: mydummy
    contains
        procedure :: do_something_else => do_something_else_local
    end type
contains
    subroutine do_something_local(this, item)
        class(t1), intent(IN) :: this
    end subroutine
    subroutine do_something_else_local(this, item)
        class(t2), intent(IN) :: this
    end subroutine
end module mod2
[/fortran]
The compiler complains that the procedure signature of do_something_else_local is different from that of do_something_else, and therefore cannot override it; overriding do_something with do_something_local works fine, so it seems to be a rank issue. Am I wrong here?
This problem has been fixed in our sources. I expect the fix to appear in Update 3.
The compiler's behavior here makes no sense to me. I will ask the developers about it. Your code looks fine to me, and certainly overriding do_something_else with do_something_local should fail. Issue ID is DPD200163706.
