Unresolved C external
mhovers
OK, I went back to basics:
IVF code:
program fortran_c_test
implicit none
interface
subroutine c_code_test(index,foo)
!DEC$ ATTRIBUTES C, ALIAS:'_c_code_test' :: c_code_test
integer index
real(8) foo
end subroutine c_code_test
end interface
integer index
real(8) foo
index = 3
call c_code_test(index,foo)
write(*,*) foo
stop
end
MVS C++(C) code
#include
void c_code_test(index,foo)
int index;
double *foo;
*foo = 3.21 * index;
This is compiled and put into: C:mhoversfortran_c_testDebugc_code_dir.lib
In Project->Linker->Input->Additional Dependencies I have c_code_dir.lib
In Project->Linker->General->Additional Library Directories I have
In Tools->Options->Intel Fortran->General->Libraries I have
When I build fortran_c_test I get:
error LINK2019: unresolved external symbol _c_code_test referenced in function _MAIN__
Have I screwed up the INTERFACE or what?
Please don't start a new thread for the same topic - reply to your other thread instead.
If your "C++(C)" code has a .cpp file type, you need to add:
extern "C"
before the "void" so as to suppress C++ name mangling.
mhovers
Sorry about the new threads, I will use "reply" from now on.
The C code is c_code_test.c and I have set:
Project->Properties->Configuration Properties->C/C++->Advanced/Compile as C Code (/TC).
However, my f90 application still give an unresolved external for the _c_code_test.
thanks
Les_Neilson
Valued Contributor II
Try replacing
void c_code_test
with
void __stdcall c_code_test
(Note thedouble underscore)
Les
anthonyrichards
New Contributor III
With 'ATTRIBUTES C' set in the Fortran, perhaps ' __cdecl' in the C might be needed.
Also, in the Fortran,I think 'VALUE' and 'REFERENCE' attributes should be specified for the 2 arguments.
Les_Neilson
Yes of course. I was looking at our ownFortran->C code and jumped in without looking carefully at the OP code. :-(
In the Fortran help look for "Attibutes Properties and Calling Conventions"
Les
I just tried the code in the original post and it linked fine for me without errors. I will agree that in the Fortran code, "foo" needs to have !DEC$ ATTRIBUTES REFERENCE :: FOO added so that it is passed correctly. All I can think of is that the C object is not being linked in. The build log should show this.
mhovers
------ Build started: Project: fortran_c_test, Configuration: Debug|Win32 ------
The build log is below, I looks like it is looking in c_code_dir.lib??
Linking...
Link /OUT:&quotDebug/fortran_c_test.exe
" /INCREMENTAL:NO /NOLOGO /LIBPATH:&quotC:mhoversfortran_c_testc_code_dirDebug" /MANIFEST /MANIFESTFILE:&quotC:mhoversfortran_c_testdebugfortran_c_test.exe.intermediate.manifest" /DEBUG /PDB:&quotDebug/fortran_c_test.pdb" /MAP:&quotfortran_c_test_map" /SUBSYSTEM:CONSOLE c_code_dir.lib &quotDebug/fortran_c_test.obj"
Link: executing 'link'
fortran_c_test.obj : error LNK2019: unresolved external symbol _C_CODE_TEST referenced in function _MAIN__
Debug/fortran_c_test.exe : fatal error LNK1120: 1 unresolved externals
fortran_c_test build failed.
mhovers
Maybe the problem is in the building of the C code library??
Under Project Defaults I have:
Configuration type: Static Library (.lib)
Use of MFCUse Standared Windows Libraries
Use of ATLNot Using ATL
Minimize CRT Use in ATLNO
Common Language Runtime supportNo Common Language runtime support
Are there any things I should check in the C library build??
thanks
Visual Studio is not even trying to link in your library.
Are you using VS2005? If so, have you installed VS2005 Service Pack 1? If not, uninstall the Intel Fortran integrations, install VS05 SP1 and reinstall the integrations. This will probably fix the problem.
Next, is the static library project a "dependent" of the executable project? Right click on the executable and select Dependencies. Make sure the box for the library is checked.
Mike_H_
I will have to install the service pac. I only mess with the fortran integration with MVS every couple of years when I get new systems and it never goes smoothly. Can you tell me the order. Should I 1) instlll MVS, 2) install the survice pac, 3) install IVF ? I can't remember if I need IVF installed before MVS for it to do the integration or not?
The above assumes that I uninstall everything and start from scratch, which is usually the only way I can get any of the MVS IVF inegration to work, but I would try to "uninstall the IVF integration, and re-install it if you can direct me to how to do that.
thanks very much
1. Control Panel > Add or Remove Programs. Select Intel Visual Fortran Compiler 10.0 Integrations in Microsoft Visual Studio and click Remove.
2. Download and install VS2005 SP1.
3.. Locate the file C:Program FilesIntelDownloadIntelFortranCompiler10installsw_ide_p_10.0.xxx.exe (where xxx is the latest number on your system - the _p_ may be _c_ instead) and run it.
This should take care of it.
mhovers
OK, got the service pac installed and the IVF fortran interface re-installed. Still no joy.
For completeness here is the code and build.log
implicit none
interface
!DEC$ ATTRIBUTES VALUE :: index
!DEC$ ATTRIBUTES REFERENCE :: foo
integer index
real(8) foo
end interface
integer index
real(8) foo
index = 3
write(*,*) foo
stop
end
C- Code:
#include
void
int
index;
double
*foo;
Build Log:
Compiling with Intel Fortran Compiler 10.0.025 [IA-32]...
ifort /nologo /Zi /Od /module:&quotDebug/
" /object:&quotDebug/" /traceback /check:bounds /libs:static /threads /dbglibs /c /Qvc8 /Qlocation,link,&quotC:Program FilesMicrosoft Visual Studio 8VCin" &quotC:mhoversfortran_c_testfortran_c_test.F90"
Linking...
" /INCREMENTAL:NO /NOLOGO /LIBPATH:&quotC:mhoversfortran_c_testc_code_dirDebug" /MANIFEST /MANIFESTFI LE:&quotC:mhoversfortran_c_testdebugfortran_c_test.exe.intermediate.manifest" /DEBUG /PDB:&quotDebug/fortran_c_test.pdb" /MAP:&quotfortran_c_test_map" /SUBSYSTEM:CONSOLE c_code_dir.lib &quotDebug/fortran_c_test.obj"
fortran_c_test.obj : error LNK2019: unresolved external symbol c_code_test referenced in function _MAIN__
fortran_c_test - 2 error(s), 0 warning(s)
Is this a naming convention problem now?
There's something odd in that log - it shows the C library being first in the link. That's not right and is the cause of the problems.
I have attached a ZIP of a working build. Compare it to yours. In particular, make sure that the Fortran project is the "start up project" (shown in bold) and that the C library project is a dependent of the Fortran project.
mhovers
Your project works fine. I notice that you have the C and Fortran all in one. I had a seperate C project to build a static library and a seperate Fortran project that tried to link to it.
Where can I find instructions on how to have multiple directiories and source code types in one project as you have done?
Thanks very much for all your help, I never would have figured this out (may still not when I have to go add the real stuff) without your help.
cheers
What I have is still two separate projects, but they are together in one solution. You can still do this - right click on the solution in the Solution Explorer pane, select Add, Existing Project. Browse to the .vcproj file of your C library and add it. I happen to like to keep the directories together, but they don't have to.
To do this from scratch, use Add, New Project. Either way, you'll then want to right click on the executable project, select Dependencies, and check the box for the library project. Also make sure that the executable project is the "startup project" (shown in bold). If not, right click on it and select Set As Startup Project.
How did you specify that the C library should be linked in?
mhovers
In MVS before the upgrade to SP1 there was a button under Project types -> Visual C++ to build static libraries (*.lib). That is gone now. How do I build a static library project now?
I don't know what it was like before SP1, but for Visual C++, you select a Win32 project and then when the project wizard opens, static library is one of the additional options choices.
mhovers
I am trying to reproduce the example you sent which works on my system. I have created the 2 projects, built the static lib and set the dependencies in the fortran project. When I try to build I get the following errors.
I have tried to compare all of the properties between your projects and mind and can find no differences (although I know they must exist). Somehow my build is having trouble with MSVCRTD.lib but I cant figure out why?
Linking...
Link /OUT:&quotDebugfortran_c_test2.exe
" /INCREMENTAL:NO /NOLOGO /MANIFEST /MANIFESTFILE:&quotC:mhoversfortran_c_test2debugfortran_c_test2.exe.intermediate.manifest" /DEBUG /PDB:&quotC:mhoversfortran_c_test2debugfortran_c_test2.pdb" /SUBSYSTEM:CONSOLE &quotDebugfortran_c_test.obj" &quotc:mhoversfortran_c_test2debugc_code.lib"
c_code.lib(c_code_dir.obj) : warning LNK4075: ignoring '/EDITANDCONTINUE' due to '/INCREMENTAL:NO' specification
MSVCRTD.lib(ti_inst.obj) : error LNK2005: &quotprivate: __thiscall type_info::type_info(class type_info const
&)" (??0type_info@@AAE@ABV0@@Z) already defined in LIBCMTD.lib(typinfo.obj)
MSVCRTD.lib(ti_inst.obj) : error LNK2005: &quotprivate: class type_info
& __thiscall type_info::operator=(class type_info const &)" (??4type_info@@AAEAAV0@ABV0@@Z) already defined in LIBCMTD.lib(typinfo.obj)
LINK : warning LNK4098: defaultlib 'MSVCRTD' conflicts with use of other libs; use /NODEFAULTLIB:library
Debugfortran_c_test2.exe : fatal error LNK1169: one or more multiply defined symbols found
The C++ project defaults to using the multithreaded debug DLL libraries, whereas the Fortran project is using the multithreaded debug static libraries. I changed the C++ project (under Code Generation) to match.
mhovers
OK, now I can build my version of the test code. Now I am trying to get it real. I need to allocate memory in the fortran and pass it into the c code. I have:
implicit none
interface
subroutine c_code_test(index,foo,val)
!DEC$ ATTRIBUTES REFERENCE :: val
integer index
real(8) foo
complex(8) val
end interface
integer index, n, i
complex(8), dimension(:), allocatable :: val
n=5
allocate(val(n))
do i=1,n
val(i) = dcmplx(0.5, 1.2) * i;
end do
index = 3
call c_code_test(index,foo,val)
write(*,*) foo
stop
end
#include
typedef struct { double r, i; } doublecomplex;
void c_code_test(index,foo,val)
int index;
double *foo;
doublecomplex *val;
As long as val is a single complex(8) all is well, but as soon as I allocate val I get:
C:mhoversfortran_c_test2fortran_c_test.f90(29) : Error: The shape matching rules of actual arguments and dummy arguments have been violated. [VAL]
compilation aborted for C:mhoversfortran_c_test2fortran_c_test.f90 (code 1)
The c_code_test routine matches the real c code I am trying to interface, so any changes to make this work need to be in the calling fortran code.
thanks,
