29562 Discussions
Unresolved external pointing to CESHELL.lib
William_A_
Hi all.  This has probably been asked before, but I can't find it in the database.
I'm using IVF 13.1.119 with MS VS 2010 and Winteracter 9.0 on 64-bit Windows 7.  I have an application that was running under IVF 10 and VS 2008 with Winteracter 7.0 under XP 32-bit and am trying to get it to compile under the new system.  I am getting several unresolved external pointers so I know I don't have the libraries quite right (or at least I think that is the problem).  The issue is that one unresolved external (SHGetMalloc) points to the library CESHELL.LIB.  However, that library does not appear to be included in my VS 2010 application (although I can find it in the VS 2008 installation on my old computer).
Does anyone know where CESHELL.LIB resides in VS 2010 and how I can get it included in my link file?
There are a bunch of other unresolved externals symbols so this might be a manifestation of a larger configuration issue related to Winteracter (since these are all unresolved externals coming from Winter.lib).  The other ones that are unresolved are:
1>winter.lib(wcomdlg.obj) : error LNK2019: unresolved external symbol __imp__SHGetMalloc@4 referenced in function _YYSELECTDIR
1>winter.lib(wcomdlg.obj) : error LNK2019: unresolved external symbol __imp__SHBrowseForFolderA@4 referenced in function _YYSELECTDIR
1>winter.lib(wcomdlg.obj) : error LNK2019: unresolved external symbol __imp__SHGetPathFromIDListA@8 referenced in function _yyBrowseCallbackProc1@16
1>winter.lib(wcomdlg.obj) : error LNK2019: unresolved external symbol __imp__DeviceCapabilitiesA@20 referenced in function _YYPSDPRINTERCAPINT
1>winter.lib(wopsys.obj) : error LNK2019: unresolved external symbol __imp__RegDeleteKeyA@8 referenced in function _YYREGKEYDEL
1>winter.lib(wopsys.obj) : error LNK2019: unresolved external symbol __imp__RegCloseKey@4 referenced in function _YYREGVALDEL
1>winter.lib(wopsys.obj) : error LNK2019: unresolved external symbol __imp__RegDeleteValueA@8 referenced in function _YYREGVALDEL
1>winter.lib(wopsys.obj) : error LNK2019: unresolved external symbol __imp__RegOpenKeyExA@20 referenced in function _YYREGVALDEL
1>winter.lib(wopsys.obj) : error LNK2019: unresolved external symbol __imp__RegQueryValueExA@24 referenced in function _YYREGKEYGET
1>winter.lib(wopsys.obj) : error LNK2019: unresolved external symbol __imp__RegSetValueExA@24 referenced in function _YYREGKEYPUT
1>winter.lib(wopsys.obj) : error LNK2019: unresolved external symbol __imp__RegCreateKeyExA@36 referenced in function _YYREGKEYPUT
1>winter.lib(wopsys.obj) : error LNK2019: unresolved external symbol __imp__GetUserNameA@8 referenced in function _YYUSERNAME
1>winter.lib(wopsys.obj) : error LNK2019: unresolved external symbol __imp__FindExecutableA@12 referenced in function _YYASSOCEXE
1>winter.lib(wdump.obj) : error LNK2019: unresolved external symbol _ClosePrinter@4 referenced in function _yywprgetdc
1>winter.lib(wdump.obj) : error LNK2019: unresolved external symbol _DocumentPropertiesA@24 referenced in function _yywprgetdc
1>winter.lib(wdump.obj) : error LNK2019: unresolved external symbol _OpenPrinterA@12 referenced in function _yywprgetdc
Bill Asher
William_A_
Ah, never mind. The answer was in the Winteracter documentation.
