29391 Discussions
Unresolved external symbol in vs2019 c++ program when calling fortran code
Colder
Hello everyone!
  I'm a user of visual studio 2019(VS2019) and I'd like to call a fortran function "hellof" in my C++ program, so I compile the fortran code in VS2019 "static library" and got FLib.lib file. I added the path of lib file into Linker->general->additional depedent directory  and name of lib file into Linker->input->additional dependencies, however when I built my c++ program, there came a error "Link2019 unresolved external symbol _hellof"
   Here are my fortran code and c++ code:
fortran:
subroutine hellof()
write(*,*) "Hello World!!!"
end
c++ :
extern "C"
void hellof();
int main()
hellof();
Note that I'm using the latest oneAPI tools and built C++ in debug mode(×64).
Since I'v tried many methods post on the net and still got confuesd, could you please give me some instructions on how to solve it? Many thanks!!!
jimdempseyatthecove
Fortran defaults to making the external symbols (hellof in this case) to all upper case.
To make compatible with C calling convention use BIND:
          subroutine hellof() BIND(C, NAME="hellof")
Jim Dempsey
Colder
Thanks so much, I've found how intel fortran compiler compiles these code and I solved the problem!
Steve_Lionel
You don't need the NAME= in this case - just using BIND(C) will make the name lowercase.
The uppercase name is the Intel Fortran default. Other compilers, or the Intel compiler on other platforms, may have different defaults.
Colder
Thanks, Steve. Since I used GUN compiler to compile fortran before, which will turn the fortran subroutine name to lowercase and add a '_' after it, thus I usually call fortran function in C++ code with same name as what GNU compiler got(lowercase and _). The case is difference between intel fortran and GNU gfortran. In short, I've found the difference and solved my problems. Thanks for your feedback again!
