Unresolved external - why?
Adrian_F_1
I have a simple module containing 2 subroutine and 1 function:
      module testbug
      contains
      SUBROUTINE sub1(n,x)
      IMPLICIT NONE
      INTEGER :: n
      REAL*8  :: x(n)
      REAL*8  :: f
      REAL*8  :: func3
      f = func3(n, x)
      return
      END SUBROUTINE sub1
      SUBROUTINE sub2(n,x)
      IMPLICIT NONE
      INTEGER :: n
      REAL*8  :: x(n)
      REAL*8  :: f
      REAL*8  :: func3
      f = func3(n, x)
      return
      END SUBROUTINE sub2
      REAL*8 FUNCTION func3(n,x)
      IMPLICIT NONE
      INTEGER :: n
      REAL*8  :: x(n)
      func3 = 0.5d0
      return
      END FUNCTION func3
      end module testbug
called by a test program:
      program main
      use testbug
      implicit none
      integer :: n = 2
      real*8  :: x(2)
      x(1) = -1.d0
      x(2) = +1.d0
      call sub1(n,x)
      end
Yet when I link with:  ifort main.f90 mod.f90, I get:
mod.obj : error LNK2019: unresolved external symbol _FUNC3 referenced in function _TESTBUG_mp_SUB1
main.exe : fatal error LNK1120: 1 unresolved externals
Any idea why?
Arjen_Markus
You declare the function func as being external, remove the line "real*8 func" from the source code of sub1 and sub2.
Also you should invert the file names on the command-line: the compiler processes the files in the order in which they appear. It may be using an old module intermediate file to compile main.f90.
Adrian_F_1
Like this?
      IMPLICIT NONE
      INTEGER :: n
      REAL*8  :: x(n)
      REAL*8  :: f
      external func3
      f = func3(n, x)
      return
      END SUBROUTINE sub1
Doesn't compile:
mod.f90(11): error #6404: This name does not have a type, and must have an explicit type.   [FUNC3]
      f = func3(n, x)
Adrian_F_1
Also why does it complain only about sub1, not sub2, which are identical?
Arjen_Markus
No, I meant completely remove it, not replace it ;). As for the reason the compiler/linker complains about only one, it may be that it is abbreviating the messages.
Just tested it to be sure and the compiler is completely satisfied with that solution.
Adrian_F_1
great thanks, works fine.
