29647 Discussions
Update 5 breaks VS Help integration (again)
DavidWhite
Valued Contributor II
Since installing 11.1 Update 5, I have lost the Fortran Help file integration in VS2005. Doing repair of the install does not fix it.
David
IDZ_A_Intel
F90 help integration is retained with the 11.1v5 update on VS2008; the first time help is invoked, the system rebuilds itself, takes some time to complete.
It works for me in VS2005. Anyone else seeing a problem?
Try an uninstall and reinstall of the compiler.
DavidWhite
Steve,
I tried doing a repair of the install and this did not work. In the end I repeated the H2reg commands that you gave previously (with modification to point to the right folder) and this gave access tothe Intel files.
David
