Updating mkl to v10.3.3
Roger_Farrow
I'd like to update my mkl installation, bundled with Visual Fortran Profor Windows 11.1.07, without creating a standalone version of mkl. The latest mkl installer, even if custommode is selected, installs in a directory called Composer XE-2011 and requires installation of MSVisual Studio integrations. I'm worried I'll end up with parallel versions of mkl and a lot of work to straighten things out.
Is there another installer available for updatingbundled versions of mkl?
No., there is not another installer. MKL 10.3 installs under Composer XE 2011 by default. But you should be able to choose a custom install and select a different location (I have not tried this.)
Roger_Farrow
Hi Steve,
yes, you can choose any location for the folder Composer XE-2011. :-(
I can always move the lower directory treetothe location of the older version of MKLbut was worried about messing up the integration with Visual Studio.
Roger
