Upgrade of computer
Howard_Lee
Our IT is going to upgrade my system from Window XP to Window 7.
They way they work is they give me a loaner machine with my current disk - that should still work, then they install Window 7 on my system with a new disk. After they return the new system, they take away the loaner system - with disk, and the disk is used for the installation of next system.
My question is, i have install Intel Fortran (purchased around this January) on my current XP. What is the suggest way to do the new install on my Window 7? (Is uninstall under XP, then re-install under Window 7 ok?)
Howard
There is no need to uninstall - we allow you to install on as many PCs as you want as long as you are the primary user. What I suggest you do is copy the contents of Program Files\Common Files\Intel from the old PC to the new. Then install Intel Fortran on the new PC.
